How do i know which brd to replace the smell on two brds but nothing look burnt
    Master:
  • 742 Answers
You have to do some troubleshooting to find the problem.
Posted on Nov 18, 2014
Hi, I have a toshiba A300-035 psagoc-03501c I own it since 2 years. I was doing normal work, when it suddenly started to smell kind of burn smell. And a blue screen appeared and nothing. Now, i...
Hi there! Normally, in this case, since the laptop just had a burning/burnt smell, it does suggest that something has been burnt inside it. It could be the motherboard itself or the processor.
If this laptop is still under warranty, you can try calling Toshiba Support line to have it taken care of. Normally, it will require for you to ship it over to their Depot, and from there they will be able to know which part/parts are bad and have it replaced.
Although, if this is NOT under warranty anymore, you will need to pay for the said hardware replacement.
Whichever way, I would strongly recommend for you to contact Toshiba so that they can give you options on how to fix your laptop.
Apr 08, 2011 | Toshiba Satellite A300-0CF035 Notebook
I have a RCA Rear projection TV and the picture on it looks like a bow tie
This problems u have is known as Convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-$350 for parts and labors.
Aug 16, 2010 | RCA P52929 52" Rear Projection Television
I have the same problem but nothing has worked! There's a bit of a burnt smell inside the unit but it powers up ok - well to the point of the annoying 'eject' sounds, and the more frustrating problem of...
This is commonly a 'capstan motor' the part that drives the tape. This causes no eject, sometimes a burnt smell and blown internal fuses.
The motor needs replacing, possibly a fuse and a check for why it has a burnt smell.
May 04, 2010 | Canon MV800i Mini DV Digital Camcorder
Burnt, scorched smell in the dryer
Remove the bottom front panel(2-3 screws along the very bottom. . Clean inside... Be really careful around the ignitor they are fragile but take care to make sure there is nothing inside the burner tube.
I hope this helps please let me know if you need further assistance.
Apr 13, 2010 | Amana ALE331RAW Gas Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Hello, Has anyone ever had to replace the Part
If you had replace the y buffer board and it's doing the same thing, you might have a bad panel.
Dec 05, 2009 | Samsung PS50P7H 50 in. HD-Ready Plasma TV
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Burnt smell like a petroleum product.ford taurus 2001 3.0
Was car overheated? I've had head gasket problems with Ford b4 and you may have a bad heater core as well and this could be the reason you are smelling a petroleum smell.
Apr 09, 2009 | 2001 Ford Taurus
On the harp al-1631 what does the flashing f then 5 mean ?
*** ALWAYS DICONNECT POWER SOURCE BEFORE REPAIRS****
Check and clean white stripe, make sure it is clean and white.
Check and /or Replace the exposure lamp, they go bad and cause F-5.
If lamp is good, replace exposure lamp sensor.
Check connector ( flat cable) connections to scanner brd.
Replace scanner brd ( board) if defective.
If scanner brd is good, replace power brd.
Jan 18, 2009 | Sharp AL 1631 Copier
Overheating? burnt oil smell
There is a seal between the compressor and the motor that in failed condition will leak oil into motor windings causing burnt oil smell. Some hitachi compressors suffered from failed valves or head gasket causing extra heat but not oil smell. These compressors also have a thermobreaker built into the windings that when failed will prevent motor from starting or would start and run for only a few moments then open. This part is not replaceable. enjoy
Oct 31, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
