Question about Kodak CAROUSEL 650H ELH Light Bulb Lamp 300 Watts 120 Volts GY5.3 2-FLAT PINS Base MR16 2.500 Amps 300W 120V O-64660 P-13096 LIGHT BULB LAMP
My slide projector light won't come on. Every thing else works
Put in a new bulb no light
    Master:
  • 742 Answers
Check the base where the bulb connects, pins get bent and don't connect to bulb at times
Posted on Nov 18, 2014
I replaced the bulb, works fine but now there is no light projection to view slides what do I need to replace?
It definitely has a lens in it then? Kids take them out to play with them and they are pretty useful as a magnifying glass.
If the projection bulb works and there is a lens in it, the only thing it can be is the shutter that comes across the lens to blackout the screen as the slide is changing. As the carousel starts to move, the shutter comes across, the old slide is removed, the new one inserted and then the shutter retracts to show that slide on the screen.
How you get to it and what is likely to be wrong with it, I am not sure, a linkage come off it or something similar?
Jan 24, 2016 | Kodak Carousel 4600 Slide Projector
Can I still buy a new 150watt bulb for an old Elmo Slide Projector CV and CS
never tried them personally but you could try
http://www.bulb-source.com
Jan 23, 2013 | Elmo Projectors Office Equipment &...
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
Manual for kodak ektasound moviedeck projector 275
Check with www.micro-tools.com for parts and manuals!! They have an amazing inventory of classic Kodak parts for slide & movie projectors! Good Luck !! Jim
Jun 05, 2012 | Kodak Vintage Ektasound Moveideck 265...
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
Projector powers on but bulb doesn't light up. Changed bulb, still doesn't work. Tried original bulb in other projector, works fine.
If you feel that it is working abnormally you can send it to service. In the USA Braun service is: HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Otherwise contact the service center in your country.
Mar 05, 2011 | Braun Novamat E150 Slide Projector
Projector light does not shine. (Power is on, bulb
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
Dec 16, 2009 | Kodak Ektapro 9020 Slide Projector
Light won't come on, replaced old light bulb.
First, check to see if the lamp lights at all (spill light coming out of the projector near the fan). If it does, then the problem could be just the "dark shutter" not opening. If the lamp does not light, it could be a couple of things: it could be the lamp thermal fuse has opened or it could be a bad lamp socket.
Sounds like you need to seek out a factory-trained repair dealer for this one, to narrow down the possibilities!
Apr 20, 2009 | Kodak Carousel 5600 Slide Projector
I can't get the light to come on.
Sounds like your black screen shutter is not opening allowing light to pass through. Try it with the carousel and slides installed. Run a few passes.
Mar 05, 2007 | Vivitar V5000AF Slide Projector
Kodak CAROUSEL 650H ELH Light Bulb Lamp 300 Watts 120 Volts GY5.3 2-FLAT PINS Base MR16 2.500 Amps 300W 120V O-64660 P-13096 LIGHT BULB LAMP Logo
111 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
