Question about KitchenAid Food Processors
What do I check to see why my food processor will not turn on?
Checked power source, blades,and all moving parts. Nothing seems to work
  • Di Patel Nov 19, 2014
    should have read - Have you checked the fuse in the plug? It could also be a broken wire inside the main sheath near the plug or the processor. That's if something like motor or switch inside has not gone faulty.
    Sergeant:
  • 266 Answers
Have you checked the fue in the plug?
It could also be a broken inside the main sheath near the plug or the processor. That's if something inside has not gone faulty.
Posted on Nov 18, 2014
Testimonial: "Thanks. Did not think of that. Will check it out"
snakehead
  • 1074 Answers
SOURCE: Food processor blade stuck on motor shaft
my friend if you had not removed that blade for a while it will certainly stuck due to the moisture that forms on the shaft of the blade holder causing it to have corosion you will have to carry that item to be removed by a qualified tech by you doing it your self could cause damage,which could cost you more.good luck
Posted on Jun 19, 2007
SOURCE: Wolf Gang Puck 620 Food Processor - Broken Blade - Need replacement
You guys with the Wolfgang Puck processor, need to go to this website, they have what you need but not what I need, I need the spindel, the blade is $9.99 www.wpcookware.com
Posted on Oct 22, 2008
SOURCE: Replacement parts for Bravetti platinum pro food processor
for replacement parts on bravetti products call 1-800-798-7398 or www.euro-pro.com
Posted on Apr 15, 2008
  • 10865 Answers
SOURCE: where can I buy repair parts for food processor
Call 1-800-851-8900 and order what you need directly from Hamilton Beach.
Please mark this as a fixya! thanks
Posted on Mar 18, 2009
  • 17 Answers
SOURCE: no manual or instructions for pro classic
Go to the following website. You will find a downloadable copy of your manual there, for free:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10C-_E
Posted on Jul 09, 2009
My Cuisinart mini food processor has worked beautifully. Now the blades are turning but nothing is being chopped or ground. Thanks!
the drive connection for the blades has probably stripped out and not driving the blades when there is work to do
Nov 08, 2015 | Cuisinart DLC-2 Mini Prep Plus Food...
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Jan 03, 2015 | KitchenAid Food Processors
In need of Bowl and blade
GENERAL ELECTRIC FOOD PROCESSOR MODEL 106622F WORK BOWL
I was able to locate a bowl for the 106622F processor on E -Bay. You may be able to find a blade on E-Bay. From what I gather, there is no source for replacement parts, other than used parts. I hope this helps ! Good Luck....
Mar 31, 2014 | GE 106622F Food Processor
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down.
so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
Jan 05, 2014 | KitchenAid KFP740 Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
Black & Decker Food Processor F1-CFP-10 need the BLADE
I have the Black & Decker Shortcut food processor Model CFP10 and it has a broken bowl. I would prefer to replace the bowl but haven't found a source. So I would be willing to sell the good parts: Food Pusher, Food Chute/Cover; Food Fingers/ Reversible Disc, Disc Stem, Knife Blade. Make me an offer and e mail me at:
hersh@powwwer.net. I'll accept Pay Pal or certified checks.
May 16, 2009 | Black & Decker FP1400 Quick N Easy Plus...
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
May 09, 2009 | KitchenAid Food Processors
I need chopping blade for Hamilton Beach food processor
I have the same issue no one seems to have the blade
Nov 16, 2008 | Food Processors
Food Processors Logo
340 people viewed this question
Top KitchenAid Food Processors Experts
Shehu Pro
Shehu Pro
Ted Maxwell
ray gallant
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
