Question about LG VX Cell Phones
My phone will not come on even with new battery
My phone got to where it would not charge or even show charging. I replaced the battery and still nothing. The phone gets warm when plugged in.
SOURCE: phone does not stay on
Ljbab try changeing the chargeing cabel
Posted on Jan 16, 2008
priyabrat
  • 123 Answers
SOURCE: CELL PHONE NOT CHARGING
If your phone won't charge via your computer using a USB cable or via your pickup via a car charger, will it charger via the regular travel charger (i.e., plugged into the wall)? If it won't charge that way either, then the issue is with the connection or with the battery. If you replace the battery and it still doesn't charge, then the problem is with the connection. If this is the issue, then I would suggest replacing your phone, especially if it is 2 years or older. If it is a new phone and under 12 months old, then I would suggest getting a warranty replacement from your provider. If it is older, and you don't want to replace it, then try gettin a new battery, however, if it still doesn't charge, then like I said previously, it is the connection and it would be less expensive to replace the phone then to repair the connection. Hope this helps and let me know if you need any additional information.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 11, 2008
RaeYa
  • 55 Answers
SOURCE: Krzr won't turn on
I would inspect your connectors (both charger & phone) as well for dirt, debris, or damage.
I would also suggest using Motorola's wall chargers, the products seem to charge best with them rather than the after-market knock-offs which also seem to damage the phones connectors on some models.
If there is damage to your connector , you will need to get your phone serviced.
Posted on May 22, 2008
fwadley
  • 482 Answers
SOURCE: BATTERY UNABLE TO CHARGE
shorting out battery
Posted on Apr 17, 2009
  • 6 Answers
SOURCE: Shows fully charged (plug icon), but isn't taking a charge. A;ready tried reboot/restore.
Get a can of air and blow it into the 30-pin connector and headphone jack to clear the phone of dust and build-up. This should clear up the problem. I learned this from an Apple Store Genius Bar associate.
Posted on Jun 01, 2009
My Samsang CE 0168 just when dead and not showing that it is charging. What could be the problem and can a new battery for the phone be fitted or?
When some batteries go bad they will not even take a charge and no charging indication is manifested. Yes, I would replace the battery.
Sep 16, 2016 | Samsung Cell Phones
Why its battery quickly drains
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 18, 2011 | Motorola Mobility C168 Cellular Phone
CE110 cell phone would not hold a charge. Bought a new battery, thought the problem was solved. But noooooo. After a day or so with the new battery, same thing was happening. Phone will not charge, and...
Since you have try several battery, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Aug 24, 2010 | LG CE110 Cellular Phone
Battery
change the phone memory
Apr 02, 2010 | LG Vu CU920 Cellular Phone
My nokia3230 does not show ''battery full''even after 12hrs of charging
You should replace your battery to a new one . after repacing if it is still not showing charging complete then it could be a hardware problem of phone
Nov 23, 2009 | Nokia Cell Phones
Battery
Your battery is gone, you will need to replace a new battery because the old battery is at it age. When you get a new battery, charge it 24 hour to fully charge it before you use, it is very crucial to maintaince the life of battery
Jul 20, 2009 | Apple iPhone Smartphone
Battery doesn't charge
change battery first and if it stay not charging download the new software
Feb 27, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
32 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
