Question about Universal Lighting and Decor Alabaster Glass Piano Lamp
What is the order of washers to replace glass lamp shade on piano lamp
I have only purchased the replacement part for the broken shade and have all of the washers, etc. I cannot figure out the order of the washers on either side of the shade.
  • Ida Manuel
    Ida Manuel Mar 04, 2015
    I would have said it was helpful nearly 4 months ago, but after getting no help or suggestions, I took it to a professional and had it repaired for $18.00 (labor, I guess). I'll thank you for answering at all!
    Sergeant:
  • 317 Answers
Flat washer, lock washer and then the nut.
Posted on Mar 03, 2015
Kyocera c3200 error Problem
A C3200 is as follows:
Exposure Lamp Problem.
• In indicator check before starting copying, the average value in scanning of the shading plate with the CCD is 128 or more.
Solution:
Defective scanner board (KP-5063).
Replace the scanner board (KP-5063) and check for correct operation
Defective exposure lamp or inverter board.
Replace the exposure lamp or inverter board.
Incorrect shading position.
Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor.
Poor contact of the connector terminals.
Check the connection of connector YC7 on the scanner board (KP-5063), and the continuity across the connector terminals. Repair or replace if necessary.
These are direct from the Tech man.
More than likely it is the Exposure Lamp.
Hope this helps.
May 02, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
The glass shade that fits over my encon ceiling broke
Lowes and Homw Depot have a huge selection of replaceent shades for fans... Take the dimensions with you there and find a compatible shade...
Heatman101
Feb 22, 2010 | Encon Industries Dryers
Glass shade has broken looking for replacement
You can usually find replacement globes at a lighting store or try Lowes and Home Depot in their lighting and fan section
Jan 23, 2010 | Monte Carlo Manhattan Ceiling Fan
Hi sir ....... when the copier ( kyocerammita 5530
Optical system (AGC) problem
1. insufficient exposure lamp luminosity
2. defective engine pcb
3 incorrect shading position
4. defective CCD unit
check exposure lamp harness connections; adjust position of contact glass shading plate or clean/replace the scanner home position sensor; replace the exposure lamp or inverter pcb if needed; replace CCD unit or engine/main board if applicable
Jan 10, 2010 | Office Equipment & Supplies
Broken glass shade for hamptonbay ceiling fan
You should be able to locate and order a replacement globe for your fan at this web site:
http://www.eceilingfans.com/accessories_-_ceiling_fans.html
Nov 09, 2009 | Hampton Bay 24002 Ceiling Fan
I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
Hello there:
here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
best regards michael
  1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
  2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
  3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
  4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
  5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
  6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
lamp
Sep 24, 2009 | Electrical Supplies
Error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
this error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
Mar 24, 2009 | Kyocera FS-1118MFP Laser Printer
Universal Lighting and Decor Alabaster Glass Piano Lamp Logo
995 people viewed this question
Top Universal Lighting and Decor Home Experts
Donni Steen
Tom Chichester
Are you an Universal Lighting and Decor Home Expert? Answer questions, earn points and help others
