Question about HP Officejet 4622W wireless Multifunction colour ink printer
My printer does not print, I have changed all cartridges are new.
Cleaned printer, checked to make sure all cartridges are installed correctly.
    Top Expert:
  • HP Master
  • 6,702 Answers
Does the printer give any code on the screen?
Is it connected to a computer? did you setup the wireless connection?
Did the printer work before?
For you the answers will be clear, but without all these details, it is impossible to answer your question.
Just putting in new cartridges, won't solve all problems. Special not, if the cartridges were not empty in the first place.
Posted on Nov 18, 2014
SOURCE: color cartridge error message
I don't have a suggestion, but what I found when I looked closely at the plastic box that holds the cartridge; there is a small "s" shaped wire that is positioned on the side of the box. In my case, that wire was loose because a very tiny piece of plastic that holds it in place has broken off. I am still trying to see if I can get that box replaced. I don't have much hope.
Posted on Dec 20, 2007
SOURCE: check black cartridge message
This happens if you refilled the cartridges, and forgot to take out the air..
Follow this steps..
1. Switch on the printer, open cartridge bay, remove cartridge, dont close the cartridge holder flaps, directly unplug the power supply from the printer end.
2. take a soft cotton, lint free cloth, slightly swab it with pure water, wring the cloth so any excess water is removed, and clean the contact pins inside the printer cartridge holder..
3. clean the cartridge head by keeping it in hot water (about 50C) and then wiping it clean, keep it upright for a few min, and when both printer and cartridge is completly dry put it back in, voila it should not display the message now...
Posted on Mar 01, 2008
SOURCE: New color cartridge won't print in correct color
I know it sounds crazy, but I found a forum where someone suggested soaking the cartridge in hot water. A million people responded that they had been having the same problem with their HP printers and tried this technique and it worked. See the postings... http://www.fixyourownprinter.com/forums/inkjet/13694
Posted on Oct 29, 2008
SOURCE: won't print after changing print cartridge, check printer cartridge light comes on!
please install the printer hp 1200 series
Posted on May 02, 2009
mace1mace
  • 1138 Answers
SOURCE: black ink cartridge not printing
Hi!
From what you did you could have missed something... here's a link.. try to access the link and remember the procedures for the control panel of your printer and to the printer software installed on your computer..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01643376&cc=us&lc=en&dlc=en&product=3795406
Much appreciated if you rate this help...thanks..
Posted on May 23, 2010
Installed a new cartridge and no imaging is printing on photo paper
Sounds like Blocked Nozzle heads assuming its making the correct noises when press "print" If Not
First ensure connected correctly:
Control panel / Devices and printers / select printer ( make sure its the default printer) right click on printer properties : Print test page.
Next repeat but right click Printing Preferences / maintenance / Nozzle check then Head cleaning.
This generally works with printers used fairly regularly.
Where printers left for long periods may have to resort to removing offending cartridge/s and using a syringe with warm water and flexible tubing to clear blocked print head (gently !) Kitchen towel underneath the print head will show when ink / water is clear. Usually have to replace with new cartridges :Then use nozzle check.
May 14, 2016 | Epson PictureMate 500 InkJet Photo Printer
Hello, I want to ask how come i still have a black background. even I already changed the charge roll. My model is Lexmark T430.
Poor development or poorly charged toner particles cause excessive background. This is more noticeable as the print cartridge nears end of life.
Make sure the print cartridge is correctly installed and the high voltage contacts are clean.
If the cartridge is installed correctly and the problem persists, try a new cartridge. The cartridge may be nearing end-of-life.
For further assistance, please contact Lexmark Technical Support
Jul 20, 2011 | Lexmark T430 Laser Printer
I just recived a used BJC-85 its is printing fine in black and white but not color whats wrong
Try some of the following possible problems:
1. Make sure the color cartridges are installed correctly.
2. Make sure the cartridges are not expired. There should be a date on the sticker on them.
3. Make sure that the cartridges are clean. Sometimes the ink can build up on the cartridges and stop ink from coming out.
4. Go to Start -> Control Panel -> Printers and Faxes. Find your printer and right click, then press Printing Preferences. In the options there make sure that color is selected.
Apr 20, 2011 | Canon BJC 85 InkJet Printer
Don't print the black color
Doing reference on your issue. Double check the ink cartridge to make sure that the cartridge is correctly installed. Also be sure that the black ink cartridge used is compatible with the machine.
The next thing to do is a cartridge cleaning as the belief is that the print head is blocked. If you have done a thurough cleaning, the next thing to do is replace the black ink cartridge to be certain the ink cartridge is not faulty.
I have included print head cleaning instructions in case you have not done this cleaning process.
here is some information from the Brother support site:
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Cleaning the print head may solve the problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then choose ALL.
When the machine completes cleaning the print head, press Color Start. A Print Quality Check Sheet will print.
Brian
Jan 22, 2011 | Canon MX700 Office All-In-One InkJet...
Installed new cartridges in Canon i850 and printer seems as though it is printing but does not grab the paper from paper feeder and gives an error (no number). Instructs me to press REsume button and power...
I changed the USB port that the printer was connected to and... VOILA...works like a charm with the new cartridges installed. Not sure what the problem was as windows recognized the printer and the drivers were correctly installed before the new cartridges even came into the picture.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Images print to light to see
Please follow the steps to clean the print head and install it try to print
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 30, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Colour Ink
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Mar 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Changed ink cartridge, now printing with green hue
check the magenta cartridge is it not dry or try to clean the magenta cartridge nozzle and see. bye
Sep 24, 2007 | Canon I960 InkJet Photo Printer
HP Officejet 4622W wireless Multifunction colour ink printer Logo
Seeker5211
Seeker5211
