Question about Nikon D70 Digital Camera
Nikon D70 Repair
Hairline crack from fall below built in flash. As you look into eyepiece numbers across the bottom are slanted. Worth repairing?
  • RalphP Nov 11, 2007
    Actually, it not the eyepiece, its the numbers inside that you see through through the eyepiece that are slanted after the fall. If they slip any further they won't be visible.
Mr. Jodie,
Don't want to argue at all. I understand that I really don't need to have the chassie repaired. It's the indicators and readouts along the bottom of the viewfinder when you look through the eyepiece, they're slanted from the fall. The help I want is the answer to the question: Is it worth having the readout and indicators portion that are slanted fixed. The eyepiece is ok. Thanks.
Ralph P.
Posted on Nov 13, 2007
    Scholar:
  • 46 Answers
Well, it depends on the extent of the repair. You don't necessarily need to repair the crack on the chassis, just the damage to the eyepiece components. Yes, it's worth repairing. Those D70s are just the right tool for people who want fine art pictures from a camera simple enough for a novice to use. The eyepiece is your most important resource when you're shooting, so you really want to make sure that it works as well as you do!
Posted on Nov 11, 2007
  • Not Available Nov 12, 2007
    Look, you didn't ask a question. You asked for an opinion. I offered it and now you want to argue about it? What's that about? If you need technical information then ask a rational question. Are you here to pick a fight or get help?
Flash won't work on D70
Does it pop up? There can be a number of causes for this problem, from a bad circuit to a broken flash tube. Without a complete description of the symptoms I can only give you the most common cause of flash problems in the D70. If you can pop up the flash, remove the two screws under the flash and carefully pry off the flash cover. Check the flash pivot on the release side. There is a plastic piece that stick up from it that the wires go through that snaps into place, and it has a plastic piece that sticks out and operates the flash up switch. Impact can cause this pivot piece to fall into the camera so that the switch does not work. Also sometimes impact can cause the top blade of the switch to fall below the plastic piece so it doesn't close.
You have to remove the top cover and pop it into place from the inside (you could use a small hook but the wires that go through the pivot are very small and easily broken. There are any number of dis-assembly instructions on the internet, just seach. Make sure you discharge the flash capacitor or you can get a nasty shock
Apr 21, 2013 | Nikon Cameras
I have a Nikon D70. The back screen has a crack across it. What part do I need to buy for a replacement. Many thanks Barbara
Is the crack in the monitor itself or in the cover? Either way, if you want to do the replacement yourself, you can order the appropriate part from
http://uscamera.com/d70.htm
Jul 17, 2011 | Cameras
Built in speedlight on nikon d70 has stopped working. The light pops up, but no flash
If flash pops up and doesn't fire, little white pin/lever inside flash has lodged up inside flash casing and needs to be eased from where it is stuck. Careful when opening the flash up to dislodge the white plastic pin/lever, there are tiny wires you REALLY don't want to damage....
See how, with pics here:
http://www.stephanmantler.com/blog/d70s-camera-repair/
Sep 12, 2009 | Nikon D70s Digital Camera
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
ERR message on my D70
YES THE SEQUENCE MOTOR IS BAD AND THAT CAUSES THE PROBEL
Oct 27, 2008 | Nikon D70s Digital Camera
Nikon D70 flah not working, used to
I had this problem a while back, but was fortunate to get it fixed under warantee as it was less than six months after Nikon repaired my D70 for the "blinking green light of death" fault.
I'm afraid this is a repair job for Nikon or an autorized workshop. It is most likley the flash tube. If you fancy taking your camera apart (I warn you it would be a fairly difficult job) then please be aware that you may get a significant electric shock from the flash capacitor, which will remain charged.
Feb 18, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon d70 flash stopped working
Well, you are not going to like my answer. The troubleshooting guide for the D70 says it could be 1 of several PCBs (printed circuit board) being faulty or the connecting FPCs (flexible printed circuit).
You'll need to locate a local repair person or use the reapir service search here on Fixya. Nikon USA repairs will be $$$$
Feb 15, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Does Nikon D70 come with an additonal bottom to plug in Bowen Flashfill
Are you using the built in speedlight on the camera with the lens hood fitted? If you are this will cast a shadow. Try removing the lens hood when using the pop up flash.
Nov 27, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
Nikon D70 Digital Camera Logo
93 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
