Question about Sharp Microwave Ovens
How set Sharp SPC570 clock
I have held down the "T.set" button and punched the + and - button
Setting the setting the clock
Colin,
Most of the time, you hit clock, then on the keypad, punch in the time of day and then either hit clock again or hit the start button. Some models may ask you for AM or PM but it will scroll a message if it is going to ask that & will tell you what button to push. Hope this helps!
Jul 09, 2015 | Microwave Ovens
How to set clock on whirlpool X2-30ES microwave
hit the button that says clock, punch in the time with the keypad and hit clock once more.
Dec 31, 2012 | Microwave Ovens
I need the manual to set the clock on a microwave rhm 1712
Most of the time you just hit the clock button then punch in the time then hit clock again
Mar 09, 2012 | Microwave Ovens
I can't set the clock. It's a Sharp Carousel II w/ ESP - R-4K82C
Press the clear button twice and then the clock button. You can now enter the time. Press the clock button when set.
Jan 03, 2011 | Sharp Microwave Ovens
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Clock setting
Mine is a Samsung, I don't know about your brand, but mine has a "CLOCK, AUTO/START"
button. Press & hold this & punch in the numbers until have the correct time
Aug 09, 2009 | Microwave Ovens
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
37 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
