Question about Gaggia Titanium Espresso Machine
Motor is hot and shutting off
Taken apart to look for burned wires etc and motor is hot to touch
  • 67 Answers
Which motor - grinder? mechanism?
Posted on Nov 20, 2014
How do I check the solenoid for the agitate/spin cycle?
This is a known problem with the motor, not the solenoid!!! You may have to replace the motor. A way to check is when it stops, unplug the power cord and touch the motor side frame. If the motor is hot that's your problem. Be sure to unplug the power plug to the motor and look inside the connector for a burnt spot. You might just need to replace the connector.
Jan 21, 2014 | Maytag Ensignia MAV4757AWW Top Load Washer
Motor stopped dead during slow turn on grass, neons light up,but it immediatly shuts down again lights ok motor stays dead.
Hi roybruce
Sounds exactly like a brake problem.
To check this run the scooter as far as it will go untill it shuts down or 10 minutes which ever occurs first.
Then being careful not to get burned touch very carefully with your finger the brake. Located at the end of your motor attached to the free wheel lever.
This could be very hot so be careful.
If the brake or motor is hot replace the brake. If the brake is cool to the touch you could have low voltage. Have your batteries load tested to make sure. Replace batteries if needed.
Good Luck
Tim
May 03, 2011 | Invacare Supply Group Invacare Scooter...
I have power going to the fan in my refridgerator, but the fan will not come on.
Sounds like the thermal fuse in the windings may have burned out . Needs a new motor that is if the motor is not warm to touch then maybe the bearing is seized. If so it can be taken apart, cleaned and re-oiled with a good bearing oil.
Oct 28, 2010 | Amana SXD524VW Side by Side Refrigerator
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
My dryer overheats every ten minutes or so and shuts off. Now has burning smell and big burn mark on back. Is not lint!
actually i've had this exact problem.
the burn mark is from clothes sitting on that metal piece as soon as the dryer shuts off and that is still hot. then once it burns the clothes, fabric is pulled through that metal opening and falls on the other side which builds up on the bottom of the dryer. you only need take off the bottom of the dryer and vacuum it out or remove it by hand. taking it apart is difficult and can be dangerous with all the wiring inside, so try not to take off any wires, otherwise when you plug it back in it could ground to the outside of the dryer and blow the motor.
Sep 30, 2009 | Frigidaire Dryers
Humming sound and buring electrical smell
yes yes yes .you are absolutely right.its the coils in the motor burning.the motor needs replacement. Often the start relay for the motor sticks and makes the motor get too hot. This can cause the motor to over-heat and shut off on the built in safety sensor inside the motor. You may need to use a amp probe to test the motor properly, check model plate for proper amps.  If this is let go too long the motor windings can also be damaged ( they may look black instead of a nice copper color). The wires on the relay are also bad for burning off the wire terminals.   The wires at the motor should be checked to make sure they have not burned off or you can test the motor continuity with an ohm meter. See two newmotor wiring pictures.....here...and...here. The relay wires often burn off as well.
May 12, 2009 | Kenmore Washing Machines
Coleman 5KW gen motor shuts down when A/C switch turned on
Sounds like a problem with the wiring of the outlets after the circuit breaksr. Take apart the outlet box and have a look for burned or broken wires, melted outlets, and/or small critters stuck in the wiring.
I recently had to repair a generator that had its voltage regulator taken out by a frog!
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Dec 25, 2007 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
61 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
