Question about LG Washing Machines
I have a lg wm2010cw and the timer stays stuck on 58 minutes and the water keeps filling. I have replaced the main board with no positive results. Do you have any other suggestions as to what I may
WM2010cw. It originally popped a spring and fell off a shock but I re installed it. Like I said previously I replaced thr main circuit board with a new one.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 60 Answers
U ned to gently blow in air twice into the pressure gause situated at the top
Posted on Jan 27, 2015
4 Suggested Answers
  • 343 Answers
SOURCE: LG washer model WM2010CW replace door gasket. If I
I suggest you get a pro to replace the door seal. The clamps can be quite tricky. Seating the seal on the tank can also be difficult.
Not a big job for an experienced tech.
Good luck....Nomess
Posted on Aug 03, 2010
TheMobilian
  • 8220 Answers
SOURCE: Lg wm2010cw front load have oe error, I follow
might be something in the pump
Posted on Feb 07, 2011
SOURCE: my new lg wm2010cw wont stay running we start it
Washed 2 bath rugs , middle o cycle tripped circuit , now my wm 2010cm will not turn back on.
Posted on Jun 20, 2013
My LG WM2010CW washer does not fill up with water.
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you may have selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
The item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Another test u can do to check the water inlet valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is free cuz God is good!
Jul 30, 2012 | LG WM2010CW 3.5 cu. ft. Front Load Washer
Frigidaire dishwasher stuck on wash cycle, doesn't complete - model # FDB1050reb0
This model doesn't use a timer like older types, The element is turned on and off by the electronics and a failed board can cause the symptoms mentioned, thee is no real way to test the board as the integrated electronics are quite complicated. The board is easy to replace, if you can use basic tools you would be able to manage it.
The dishwasher is cold fills so heats it's own water so the hot water temperature in the house has no impact on the dishwasher.
Mar 10, 2012 | Dishwashers
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Kenmore disher skips wash cycles.
HI, this is the result of a faulty timer control module. replacing this damaged device will restore the normal functions of this unit.
Jul 17, 2009 | Dishwashers
LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Jun 01, 2009 | LG DLE2515S Gas Dryer
I have a Whirlpool AWG338 that has suddenly stopped drawing water. It will run a cycle as if water is there but never actually draws from the main. It has both hot and cold supply.
If water is not getting into the machine, and the hot and cold water faucets are connected, and have good pressure, then parts that can cause the problem are inlet valve, water level switch and timer control.
To start cut power to the applianc3e for five minutes, this can fix a jammed timer control.
If that does not work you may need to call a repairman to test the following:
The inlet valve must be tested by energizing it , testing valve solenoid, and reading voltages to identify a fault in wiring (contact).
If the inlet valve is fine when tested, worth having a look at the water level switch, if it is stuck on overfill position , it will prevent water from getting into the machine.
Lastly,the timer control board should be tested, to ensure that the problem is not a faulty timer keeping the inlet valve on close position.
Mar 30, 2009 | Whirlpool Washing Machines
No lights on prima lpr 600 dishwasher just keeps filling up with water not draining
When there is no light at all, and machine is stuck with inlet valve open from start, then it is probably a faulty timer control board.
Before replacing the control board , the inlet valve, wiring harness, and additional electronic controls must be tested.
Try also unplugging the appliance from main, or tripping circuit breaker to cut power for ten minutes. ~This may unlock a jammed control board.
Mar 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Electronic controls don't count down properly
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Nov 20, 2007 | Bosch SHU5315UC Dishwasher
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Apr 14, 2006 | Bosch SHU5316UC Dishwasher
Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Washing Machines Logo
97 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
