Question about Home
How do I fix my Flamerite Electric fire ? The glow option is not working properly - the bulbs try to light up but go out after a split second.
Changed bulbs - not the problem Checked Plug - not the problem
SOURCE: No glow plug light, car turns over but won't start, no CEL or codes
I don't have the solution but a possible help in diagnosing.  If you remove the water temperature sensor connector from the sensor, the glow plug light should stay on when you go to start the car.  Try leaving it on for 15 seconds and then start the car.  If it starts right away, it is your sensor.  If it doesn't, the good luck.
The sensor is located on the right side of the engine near the top, at the back.  It is in the coolant fitting directly behind the hose from the rad, just left of the thermostat.  Be careful to disconnect the wires, and not remove the sensor, or you will loose a lot of coolant.  The sensor is held in by a separate plastic clip, and the harness just has a little built in clip on the side.  Hope you have small hands...
Posted on Jan 06, 2009
SOURCE: brake lights went out, changed bulbs, checked fuse, still wont work
You have to check the brake light switch which should be around the brake pedal on the upperside.
Ones located rremove the wires tht go to the switch and jump them by using a piece of wire, thn check if the brake lights come 'on'. If they do , thn its the switch tht may need replacing or even sometimes adjusting inorder to operate.
Hope this helps.
Posted on May 10, 2009
  • 88 Answers
SOURCE: rear brake lights don't work
you prob got a trailer plug prob bad wires if not tail lights run through turn signal switch tell fix ya bout me ok
Posted on May 23, 2009
pippall
  • 1486 Answers
SOURCE: flashing glow plug light
sounds like a glow pug fault.it will flash if one glow plug has a fault.
Posted on Jun 03, 2009
  • 137 Answers
SOURCE: 2003 Diesel Passat - Brake lights out/Glow plug & ESP lights on
you have a bad engine earth
Posted on Jul 07, 2009
I have a flamerite milan fire suite lights not coming on checked bulbs they are OK heating working also
No power to the fire: Check the wall socket, plug and fuse. No illumination: Make sure the fire is turned on. Check heater is working, if so change lamps. Illumination but no heat: The safety cut has operated see note on operating the Fire. Noise when illuminated: Due to moving parts, the electric fire will make a noise. Noise from the heater when in use: The sound of rushing air is normal. Logo
Jan 21, 2017 | Heating & Cooling
I have a flame rite fire model number 172/180 will not work do you still have these fires
Maybe your circuit board is fried too? Circuit boards come up as issues more than a few.
Kind Regards,
Scott
Need circuit board flamerite 172 180 elect fire
How to fix flamerite fire
Feb 10, 2015 | Home
Flamerite fire spare parts
This is an issue to be resolved with Flamerite.
Oct 22, 2013 | Grilling
I have a flamerite mercia electric suite, just over 2 years old. The remote control does not now operate the heat function. I have replaced the battery but it still does not work. Any help for a...
I have the same problem phoned the makers Flamerite and they sent me some instructions that may solve the problem. Phone them on 01543251122 I did speak to the shop where I purchased the fire and they told me that this was a common problem with these fires. This did not fix my problem. I will be contacting them again tomorrow. Good luck
Oct 04, 2011 | Heating & Cooling
I have a Flamerite Odyssey Suite Electric Fire approx 5 yrs old. The thermostat no longer works and I cannot find anyone that sells a replacement. The thermostat only has the number 143211 256-C...
I have just tried to obtain a stat for this same fire Flamerite was no use at all.I have put a link in where the sta was to override, it's on full now, but theres heat now. Terry Risley Electrical Services 0788 4061406
Oct 24, 2010 | Universal Remote Control Heating & Cooling
Breakdown with Flamerite Corello FO1
my Flamerite Corello fire does not work we had to have the circuit bard fixed within the first 12months of getting it and it went again over a year ago how can i fix it
Aug 15, 2010 | Heating & Cooling
I have a Flamerite fire, model is called Isis. The fire come with a remote control which you use to turn on the lights and the heat. The fire is not working, when you press the remote the bulbs on the fire...
Hi I have the same fire with almost the same problem, I even bought some new batteries for the remote thinking that may be the problem.
I bought my fire suite second hand ,(Vega suite with Isis inset) in almost new condition and absulutely love it, so am gutted it has stopped working , Someone said , ''It could be the hidden bulbs at the backof the isis inset that need changing, But on trying to find access to the bulbs I just cannot find a way to get to them, There is 4 screws on the near inside which previous owner has cross threaded and wondered if that is the only way to get to them, If you have any ideas I would really appreciate your help and will contact you also if I can find a solution, Take care have fun
Maureena
Dec 14, 2009 | Dryers
My flamerite atlanta fire will not switch on. When i do turn the heat on the fire cuts out
Similar thing happened to mine at weekend after fitting a new hearth and fire surround (sods law) think its the heater unit £57.50 from flamerite
Sep 04, 2008 | Heating & Cooling
Home Logo
27 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
