Question about Nostalgia Electrics Hot Dog Grill Roller with Griddle
Is the connector for the motor and roller assembly available?
Model HDR 535. I have removed the broken part
The roller does not spin
Hi schrim8...
Your problem is most likely a broken drive belt.
You will have to remove the vacuum base cover, then remove the roller assembly from the vacumm base to replace the belt.
After you remove the roller assembly put the new belt on the pulley inside the vacuum first, then install the belt on the roller assembly and then reinsert the roller assembly back into the vacuum base.
Reinstall the vacuum base cover.
Please take time to rate me
Jul 28, 2011 | Eureka Uno 2998AZ Bagless Upright Vacuum
No power to brushes no result when brush switch activated
If you hear the brush moter running then the belt driving the roller has probably broken. It can be easily replaced by removing the brush plate underneath and pulling the roller out. Replacement belts are available on-line or may be available in hardware stores.Fit the new belt over the steel motor spindle first, then place the belt over the roller and insert the roller.
The belt will break if the roller gets jammed, so buy 2 belts and keep one as a spare.
Mar 07, 2011 | Bissell 3750 Lift Off Bagless Upright...
How to replace a broken wing mirror on a Volvo S40 1980 model
Power Dr Mirrors Diagnosis & Testing
Removal & Installation
Motor
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    Disconnect the negative battery cable. The mirror inside cover trim The door panel The electrical connector to mirror motor The nut attaching mirror assembly to door frame The outside rear view mirror
    Fig. Removing cover trim and nut
    Fig. Removing mirrored glass from assembly
  3. Remove the mirror glass:
    1. Fold the mirror glass forwards and inwards as illustrated.
    2. Grasp and pull the mirror glass lengthways until it releases.
    3. Work the glass out.
  4. Remove electric motor:
    1. Remove the 3 screws from behind the mirrored glass.
    2. Separate the connectors
      NOTE Remember the positions of the connectors.
    3. Remove the mirror motor.
      Fig. Removing connectors and screws holding mirror motor
To install:
  1. Install or connect the following:
    The electric motor The electrical connections The 3 screws that go behind the mirror Install the terminal pins Fold out the mirror mounting on the motor Hook the mirror glass into the inner mounting Press the mirror glass into place. Place mirror in position in door
    Fig. Reattaching mirror and electric motor connectors
  2. Install or connect the following:
    The nut attaching mirror assembly to door frame The connector The door panel The mirror inside cover trim The negative battery cable
Oct 23, 2010 | 2000 Volvo S40
1994 Jeep Grand Cherokee front passenger window will not operate where is the motor located how do I tell If it the motor,switch or regulator causing it not to work?
first check the switches on driver's door and passenger door , most often this is the cause. switch them around to check or use jumper wires in the connectors. motor is inside the door low towards the front. motor is bolted to window regulator assembly.
1. take off door panel and plastic liner
2. remove 3 or 4 bolts retaining assembly with window up, but mark exact location as this affects alignment
3. pivot assembly to remove rollers from track on glass
4. remove assembly through largest opening on inner door frame
5. un bolt motor from regulator
6. Install in reverse order
I am willing to elaborate on any and all of these points untill you are done, just reply to this feed for more info
Oct 04, 2010 | 1994 Jeep Grand Cherokee
My Whirlpool Gas Dryer Estate Model # TGDS680BW1 will not tumble when I turn it on but the motor still runs. How can I fix it?
The problem is likely the dryer belt . Here is a video on replacing a dryer belt. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Sep 17, 2010 | Estate Dryers
Belt tensioner overheated and doesn't keep belt tight enough
Looking at the owner manual, there is no tensioner assembly.
If the motor is fixed in place and not loose, then you either have the wrong belt, or the brush roller is not properly installed, or the brush roller is worn out where the belt goes around the brush roller.
Dec 16, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How to install a door glass for a Chev C10 . I am have problems install the glass at the Drivers door. I need some help. As soon as possible
GM Full-Size Trucks 1980-1987 Repair Guide
REMOVAL & INSTALLATION
(see Figures 1 and 2)
Non-Stationary Door Glass
  1. Lower the door glass completely.
  2. Remove the trim panel from the door.
  3. Remove the ventilator assembly as previously outlined.
  4. Slide the glass forward until the front roller is in line with the notch in the sash channel.
  5. Push window forward and tilt the front portion of window up until rear roller is disengaged.
  6. Put window assembly in normal position (level) and raise straight up and out.
  7. Installation is the reverse of removal.
Fig. 1: Door window and regulator
Fig. 2: Removing the door glass
Manual Door Window Regulator
(see Figure 3)
  1. Raise the glass to the full up position and tape it to the door frame with fabric tape.
  2. Remove the door trim panel.
  3. Remove the regulator to door panel attaching bolts.
  4. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
A notch is provided in the sash panel to allow disengagement of the forward roller on the window regulator.
  1. Collapse and remove the regulator assembly through the access hole in the door.
To install:
  1. Prior to installation, lubricate the motor drive gear and regulator sector teeth.
  2. Collapse the regulator and insert it through the access hole in the door.
  3. Unfold the regulator and engage the forward roller to the sash cannel at sash channel notch.
  4. Slide the regulator rearward to engage the rear roller to the sash channel. Also engage the lower roller to the regulator rail.
  5. Slide the regulator into its proper position, and insert the regulator drive through the door panel.
  6. Attach the regulator to the door.
  7. Install the door trim panel.
Fig. 3: Manual window regulator
Power Window Regulator and Motor
(see Figure 4)
Fig. 4: Power window regulator and motor
  2. Disconnect the negative battery cable.
  3. Remove the door trim panel.
  4. Remove the remote control bolts and lay the control aside for access.
  5. Remove the regulator to door panel attaching bolts.
  6. Disconnect the harness from the regulator.
  7. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
  1. Remove the regulator assembly through the access hole in the door.
CAUTION Step 9 must be performed when the regulator is removed from the door. The regulator lift arms are under tension from the counterbalance spring and can cause serious injury if the motor is removed without locking the sector gear in position.
  1. Drill a hole through the regulator sector gear and back plate. DO NOT drill a hole closer than 1 /2 inch; to the edge of the sector gear or back plate. Install a pan head sheet metal tapping screw (No. 10-12× 3 /4 inch;) in the drilled hole to lock the sector gear in position.
  2. Remove the motor to regulator attaching screws and remove the motor from the regulator.
To install:
  2. Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the retaining screws.
  3. Remove the screw locking the sector gear in the fixed position.
  4. Reposition the motor in the door and install the wiring connector.
  5. Attach the regulator to the door.
I really hope help you with this (remember rated this help) Good luck.
Oct 06, 2009 | 1980 Chevrolet Corvette
Convection microwave turntable does not turn. Makes a clicking noise.
Try removing the turntable plate, and then lift up on the roller assembly that the plate sits on. These roller assemblies are usually made of plastic, and often times the center "axle" (the part that goes down into the hole in the bottom of the microwave) breaks or cracks. If it looks like this piece is cracked or broken, just take it down to an appliance repair store (or just write down the model # of your microwave and bring it with you). Replace the roller assembly, and you're good to go.
You can also find these roller assemblies online pretty easily as well, and they're usually under $10 USD.
Good Luck.
Aug 25, 2009 | Sharp Microwave Ovens
Lda 511 will not load disc; noisy blapblapblapblap and disc just sits there.
I used an o-ring to fix the problem. Quite easy to disassemble, old belt was removed and similar size o-ring was found at a hardware shop. Put the o-ring on the pulleys and viola. 68 cent fix
Jun 06, 2009 | LG LDA511 DVD Player
Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Mar 24, 2009 | Hoover WindTunnel V2 U8148-900 Upright...
Nostalgia Electrics Hot Dog Grill Roller with Griddle Logo
214 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Wayne Fellows
Wayne Fellows
Shehu Pro
Shehu Pro
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
