Question about Dehumidifiers
What is the code 8.8 means appears on the dehumidifier
  • kakima Nov 18, 2014
    What make and model dehumidifier?
Why is water going to the bucket instead of getting pumped out the hose? Does this mean the pump has quick working?
It is possible that the drain hose is not properly positioned. It is very fussy about that. Here is a link to the manual on PDF. See pages 8 thru 12.
http://www.soleusair.com/Manuals/2013%20Manuals/Dehumidifier/SG-DEH-70EIP-6%20Manual%2012-05-12.pdf
Oct 23, 2015 | Soleus Dehumidifiers
I have a Frigidaire LAD504TDL dehumidifier and code 'ES' shows on display. What does this code mean? Unit runs but not much water in tank.
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
Jun 08, 2015 | Frigidaire Dehumidifiers
What does an A-5 error code on a Frigidare dehumidifier mean, and how do I correct it
Good Afternoon Friend, this is Z. I am happy to assist you!
I show that the correct error code your Frigidaire dehumidifier is receiving is "AS". Typically, it means that your dehumidifier is experiencing a sensor failure. I show there aren't any manufacturer replacement parts available for your dehumidifier. This could be because it is a smaller appliance and repairs are often more costly than the actual appliance replacement. Is your dehumidifier still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best of luck!
Aug 25, 2014 | Frigidaire Dehumidifiers
Is there a special code to direct water to pump, dump bucket or drain
That would be the "Pump" button on the control panel. When you press it, your dehumidifier display should indicate "PUMP", and the unit should start pumping water out that little port at the center rear of the dehumidifier.
Alternatively, you could stand the dehumidifier on a counter and direct your waste water out the larger hose connection into a sink.
I personally carry it (more than five gallons per day) upstairs to the laundry, because it's distilled water - the softest water you can get. Works GREAT in the washing machine. 8) 8) 8)
Jul 30, 2014 | DeLonghi DD50P Dehumidifier
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Apr 28, 2013 | KUL 65 Pint Dehumidifier
What does code AS mean - seems to be working fine.
Hello marilu scheck - Typically error code AS indicates that a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer and then a professional they suggest to have it repaired.
Oct 03, 2012 | Frigidaire FAD704TDP Dehumidifier
What does P1 mean
t appears to mean "defrosting." In other words, the condenser coils have gotten too cold and are icing up..
The filter is probably full, or the thermostat is faulty. Open it up and clean the filter first.
Sep 17, 2012 | Midea MDF1-30AEN3-BA4 WP 30PT ES...
Unit will not run and the code 'LO' show up. What does the 'LO' code mean?
Hi, it simply means that the humidity level is lower then 35% the lowest setting on the dehumidifier...
It will not run when showing that...
Jun 09, 2011 | Haier 45-Pint Dehumidifier
The fan is running on my dehum but it cl ollects no water. a code P1 appears in the window now.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 23, 2011 | Danby DDR2509EE Dehumidifier
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
Dehumidifiers Logo
164 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
