Question about Baumatic Dishwashers
Hi, How do I reset baumatic oven -BO625SS - following power cut please ?
Gone through instructions in manual. Last time this happened I was told to hold in two or three of the buttons in sequence but can't remember it now.
SOURCE: whirlpool oven AKZ104
Try removing the front panel and reconnecting the button,this may help.
Posted on Jan 31, 2007
  • 172 Answers
SOURCE: Need Reset code button sequence
Hi ez_drummin02,
The following link will give you step by step instructions for unlocking the controls on your dishwasher. Simply get your model number off your dishwasher and enter it into the box. The owners manual will tell you how to reset the board and locks if you have engaged the lock. http://shared.whirlpoolcorp.com/product_literature/search.jsp
Hope this will help.
Mike
Posted on Sep 30, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Dishwasher power surge results in flashing clean button
I'm not sure what the sequence would be on your particular model as Whirlpool dishwashers can differ in operaiton. However, if you remove the lower kick panel under the dishwasher door, there should be a tech sheet either directly behind the panel, or tucked inside the door. The tech sheet will list all troubleshooting tips and any fault codes that the owner/operator's manual does not list. This is the SAME sheet the repairman will reference when they come to your home on a service call. Please let me know if you still require assistance. I hope this helps you.
Posted on Oct 22, 2008
SOURCE: ASKO Dishwasher F2 light flashing
Hold the Rinse button for 5 seconds to reset.
Posted on May 19, 2009
  • 142 Answers
SOURCE: How do I reset this washer?
hold the start button down for twenty seconds with door open after that close door and see if drain pump kicks in if it does wait for it to finish and then try and reprogram it good luck.
Posted on Sep 28, 2009
After a power cut my Baumatic oven won't now work. Power is going to it, time is correctly set but oven won't turn on. Any help appreciated.
If this unit is still under warranty, Baumatic will repair it for free. Their service number is 0118 933 6911. I recommend trying them first before making any repair attempts. You could try unplugging it for a couple minutes to reset the computer.
Jun 13, 2016 | Baumatic Ovens
BO6255SS - The clock turns on but we are unable to set it and therefore cannot turn it on. Can you help?
this is as much as the manual says
After your appliance is connected to your mains supply for the
first time, the numbers on the timer display will flash. Before
you can select a cooking function or set a temperature, you
must set the appliance into manual operation mode.
o To select manual operation mode, press the manual operation
button (9) on the control panel.
http://www.manualslib.com/manual/956107/Baumatic-Bo625ss.html?page=3#manual
Jun 02, 2016 | Baumatic Ovens
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Mar 07, 2011 | Baumatic Ovens
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Oct 15, 2010 | Stoves 720EF Electric Double Oven
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Mod: BMK 2 SS. Manual has gone missing!
http://www.baumatic.co.uk/products/catalogue/microwaveovens/BTM23.1SS
I beleive this is the same item, not sure why it has a different model number on the website, but you can download the PDF of the manual from the above link.
Oct 07, 2009 | Baumatic BTM231SS Microwave Oven
Dishwashers Logo
117 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
