Question about Home
I try to go on you tube and it dont let me
To get in and it dont let me
Why cant i choose videos i find on you tube to download to my htc inspirek?
to download you tube videos you need to have you tube downloader.
if u have then check for the compactiblity as some are not compactible
Mar 06, 2012 | HTC Inspire 4G Smartphone
My sub zero model 642 leaks water from the bottom. when you take out the crisper drawers the coil looking tube behind there is full of water. I can't remove the tube to "blow it out" or to try...
Yes try boiling water and if you have a 1/4" plastic tubing like what they use on icemakers and boil some water in a pan and then siphon the water into the drain and try to push the tubing down inside the drain as your doing it to unclog/unfreeze anything in there. The tubing will get hot while your doing this you'll need a towel to wrap the tubing so you dont get burnt. Its either frozen or clogged, more than likely clogged on this model i believe. Let me konw if you need further assistance.
Sean
Mar 27, 2011 | Refrigerators
Changing tube in back tire
its take time to to change the tube if your have u dont got a tire changer (if you are only usein hand tools try not to wreck your rim or tube when relplaceing a new one.
Oct 07, 2010 | 2003 Honda CRF 150 F
I have kit, but no instructions on how to repair a bike tube. help please.I have bike tube repair kit with patches, glue and metal things
The metal thingy is used to roughen up the tube, where the patch will go, so the glue will stick. The glue may have instructions on it, but place glue onto the patch and the tube and let it dry for a few minutes, then place patch over hole.
when refitting the tube, sprinkle some powder on it around the patch and inside the tyre, make sure you have removed whatever caused the initial puncture. Try to refit the tyre without using any levers, so you dont pinch the tube again
May 10, 2010 | Cycling
The hand-held wand wont slide back into the tube. It wont go down far enough to click in and become the handle again. It was working fine but all of the sudden won't fit back in.
sounds like the tube has something inside of it that is obstructing the path. veriffy the the "female" end of the tube isnt obstructed, and also, make sure that nothing is bent ( which can happen easily). use a flashlight to shine down into the tubes and check everything out. you shouldnt need to use a lot of pressure when trying to make the tubes fit. if it doesnt fit, dont force it, basically.....try turning the tube too, and that should work.
Sep 24, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Short or long tube
If I remember correctly anything over 30" cut for the deck has the longer frame tube that you are referring to
Sep 15, 2009 | Garden
Unusal valve stem on the tire tubes how do I pump?
ok mate you have to go to a bike shop and buy a the newer tubes the one your daughter has is really old and they dont make them any more so just go to a bike shop and ask for a bike tube and then ther you go also if ya need any help putting it on just give us a bell. and dont forget to rate me .
Mar 28, 2009 | Kettler Scoot Training Bike
My you tube dont work
The YouTube server is having trouble. Just wait a few minutes and try again and it should work.
Feb 15, 2009 | YouTube Videos
50''dlp had to replace the lamp, picture not as good as before
ok what you should do is to check in the old lamp the part number and who made it. dont believe what some sellers try to envolve, if you dont have that info check with tv model what part really is missing.......saludos
Nov 17, 2008 | Samsung DLP HL-P5663W 56" TV
Home Logo
650 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
