Question about Eclipse T180 MP3 Player
My eclipse mp3 player is not showing up on the computer. it is frozen on a screen saying' loading playlist'. What do I do?
Plugging it into the computer, but it will not show up on the computer. it is frozen on that screen. Please Help?
  • 4 Answers
SOURCE: Eclipse MP3 Player
The official unofficial REAL Answer is here!!
I swore it off as Junk untill I took the time to figure this out.
When charging the power swith needs to be in the "ON" position.
Charge for around 3-5 hrs.
To turn device ON You hold down the Play/Pause button for quite some time, (much more time than expected from other players,cellphones or devices) the unit should power up and display "ECLIPSE".
I thought I was "taken" and strange when I saw the link for Qresolve within the files of something that did not work.
Theres even an EQ feature in the Menu and the sound is pretty decent. Good Luck!
Posted on Apr 08, 2010
Aeryskelle
  • 7 Answers
SOURCE: Eclipse MP3 Player- Wont charge. I plug it in and
People on other posts said to get a wall charger and that'll work. We looked for one, but couldn't find one. We ended up using a usb camera upload cord that had the same connector. It charged just fine after that. We have a 180 Eclipse mp3 player...I'm guessing the cord connectors are pretty universal.
Posted on Apr 09, 2010
muntejaya
  • 10421 Answers
SOURCE: My Eclipse MP# player reports
Please get it here :
www.ptf.com/eclipse/eclipse+mp3+drivers/
ptf.com/eclipse/eclipse+mp3+driver+software/ lki
Posted on Feb 11, 2011
  • 6771 Answers
SOURCE: I just bought an eclipse
This is a case where this should go back to the store, one option to try is all MP3 players have a reset switch somewhere on the chassis, a safety pin is bigger enough to slip in. When found press and hold for 60 seconds, If this fails take it back because there is nothing more that can be done.
Posted on Mar 20, 2011
SOURCE: eclipse mp3 player says "no file"
I had the same problem. I think most files that itunes uses are in a .m4a format. The eclipse mp3 player will need all the music files in an .mp3 format. The eclipse actually has a "software" folder that includes the "replay converter" that will convert these files for you - or you can download any number of freeware that will convert the files as well. Once I converted those files, my eclipse played everything. Prior to that - even though I had synced everything with my Windows Media player, I was getting the "No Files" message. Good Luck!
Posted on Oct 08, 2011
My eclipse fit clip shows music in the folder but wont play any
seems like the names were copied but not the music files try syncing with Windows Media player form a playlist
Dec 05, 2015 | Eclipse Audio Players & Recorders
Eclipse MP3 Player
Make sure the music files are mp3 files, not wma or some other format.
Dec 16, 2013 | Audio Players & Recorders
Frozen eclipse v180 mp3
FROZEN WHEN YOU TURN IT ON.....SO ANGRY
Dec 02, 2013 | Eclipse Audio Players & Recorders
My eclipse portable media player is frozen it turns off **** it stays on a blue screen dat says eclipse
I need detailed instruction on how to put a Eclipse V215 mp3 player back together. The warranty already expired so I'm fixing it on my own.
Jan 12, 2011 | Mach Speed Eclipse V215 (2 GB) MP3 Player
Lookins for software
HDD14xx GoGear:
manual
software and drivers
The manual shows how to make lists and transfers with your player.
A short guide on how to use Windows Media Player 11:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your music maps and ad songs by drag and drop method
onto the right saying "Drag items here"
4. when ready adding songs in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 11, 2009 | Philips GOGEAR SA6045 MP3 Player
RCA Opal not responding
Make sure all of the songs are in the right format.
If they are, then reformat the player.
browny - headphone symptom is normal. For not turning on,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 01, 2008 | RCA OPAL M4001 MP3 Player
Insignia Mp3 player frozen
If you hold the power button for 20 seconds it will shut off. I had the similar problem where I unplugged my Insignia NS4V17B frozed on the bluetooth initializing screen. I turned it off then back on and it is now working fine.
Jan 09, 2008 | Insignia NS-DV2G MP3 Player
Eclipse T180 MP3 Player Logo
126 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
