Question about Garden
Can not get to fire,or start?
Have spark. Have fuel
  • 1,169 Answers
Check for clogged spark arrestor or lack of compression. Normally needs at least 100 psi to fire. Also check that it is properly timed; otherwords, that it don't have a sheared flywheel key.
Posted on Nov 18, 2014
Testimonial: "Spark arrestor was not dirty,went ahead a burned off. Am going to ck compression now."
96 ciera 2.2 ran fine. parkedat night next morn wont start.its getting fuel and fire but sounds like its not even trying to start
Check for spark.. pull one spark plug out set it on bare metal(away from cyl hole fuel could light from spark) turn vehicle over and look for spark should be a nice lightning bolt looking spark... blue spark is weak spark.. and see if it's getting spark...,, if not,,."try new plugs.,wires,distributor cap&rotor " also first.spray a little starting fluid down the injection system turn it over and see if it fires.if it does then it's a fuel issue prob not electrical... try that.hope it helps
Dec 31, 2016 | Cars & Trucks
91 4 runner immobiliser with an equator immobiliser
I have a toyota4 runner which has an equator immobiliser now she won't fire have spark and fuel but won't start As old as this vehicle is you might think of replacing it with one that fires has spark and fuel.Goodluck )
Jul 20, 2016 | Toyota 4Runner Cars & Trucks
Want start. Getting fuel. No fire at spark plug
These engines have a low oil sensor and if the oil is low, the engine will not have fire. So check the oil level first and make sure it is to the full mark.
Check the spark plug that it still has proper gap .028-.031 in and the proper spark plug BPR6ES (NGK) or W20EPR-U (ND). While you have the spark plug out let's see that it is firing, reattach the plug wire to the spark plug and make sure the spark plug is in contact of a bare metal surface for a ground, the crank the engine over watching for spark in the gap of the spark plug. It would be best to check this in a low light area. Keep in mind that checking for spark this way and there is spark but when the spark plug is installed and there is compression the spark may not jump the gap as it should. If no spark with the plug out check the spark plug wire for cuts or tears and it none seen get a new spark plug. If there is spark with the spark plug out reinstall the spark plug. If the engine hasn't been started for some time drain the gas out of the fuel tank and carburetor. There could be water in the fuel also but to check if there is fire get a can of starting fluid. Drain the carburetor anyway at this point because if there is water in the fuel the next step may not fire the engine because of the water. Take the air filter out and give the opening of the carburetor a short spray of starting fluid. Try to start the engine, if it doesn't start or fire with the starting fluid there is something wrong in the ignition system. The Digital CDI Ignition Coil could be bad but before buying a new one you need to check the shear key of the flywheel to the crankshaft to make sure it is in good shape. You will need to remove the flywheel for this. If the key is in very good shape, then it is the coil.
If the engine fires on the starting fluid then you have water in the fuel or the fuel is not getting into the engine as it should from the carburetor. The carburetor needs to be cleaned.
Feb 27, 2015 | 13 HP Electric Start GX390
02 land rover discovery turns over but wont start
OTHER THAN A MECHANICAL PROBLEM THERE ARE 2 THINGS THAT KEEP YOUR CAR FROM RUNNING, 1 No Spark, 2 No fuel. To check fuel open the air intake and squirt a little fuel into the air intake if the car starts or at least fires you probably have a loss of fuel.. The spark problem, You need to find out if the spark plugs are firing.. if they are not firing the car will not start.. THEN YOU MUST FIND OUT WHY THERE IS NO FUEL OR NO SPARK, BUT FIRST Isolate the system THAT IS NOT functioning.
Mar 07, 2014 | 2002 Land Rover Discovery Series II
Spec vin ecu specs
If it turns, then the battery is OK. Either spark plugs are not firing in proper order (wrong firing order), no power to spark plugs, or no fuel because of fuel restrictions (dirty fuel filter). Inspect the air filter to ascertain its not clogged air. If you smell gas, then you saturated the spark plugs, which is why it refuses to run.
Let it sit for half hour to let spark plugs dry. Inspect to ascertain its not dirty spark plugs, which will also prevent engine from running. After ascertaining its proper firing order, spark plugs are clean, and there's power to distributor cap, ascertain there's fuel in fuel lines by squirting half second (short squirt) of starting fluid into air filter. Close the air filter housing to trap flammable starting fluid gas. Turn engine without giving throttle. Let starting fluid be ignited by spark plugs. If it won't start, then spark plugs are not firing to ignite starting fluid gas. If it starts briefly, but won't run when you give throttle, but catches when a 2nd person squirts more starting fluid into air filter just before engine stalls, then its a fuel restriction issue or no fuel in fuel lines.
Nov 29, 2013 | Cars & Trucks
2001 Nissan Pathfinder won't start, fuel pressure ok, spark plugs not firing
make sure you have fire at the coil if not there will be no fire to the plugs
Feb 08, 2013 | 2001 Nissan Pathfinder
Driving down road and it was like u just shut it off and now it will not start it has fire,compression,and fuel and does not have a broken timing chain
Is the fire and fuel actually reaching the combustion chambers, or just to the coil and fuel regulator. If fuel and spark and compression are all present, and the timing is correct, there is nothing to stop it from starting. Something has to be missing from the equation. Try to start the engine, then pull a spark plug. If it's getting fuel it will be wet with gasoline. Now, with the spark plug still attached to the plug wire, lay the spark plug where you can see it while cranking the starter. There should be a bright bluish white spark at the tip of the plug. If the spark is weak and yellow looking, it may not be strong enough to fire the air fuel mixture.
Mar 13, 2011 | 1995 GMC Sierra
Turns over but wont start
first check fuel, then check to see if it is fireing at the spark plug. if it is fireing at plug, check to make sure it is getting fuel. ( should be able to smell fuel on the electrode end of spark pug). If it is getting fuel, and spark, you may try removeing all spark plugs, then shoot some oil into each spark plug hole. Replace plugs, and try to start. If it still wont try to start, may be out of time. Does it pop, backfire when you are cranking the engine?
Nov 08, 2010 | 2001 Hyundai Accent
1999 cadillac sedan deville won't fire to start
you need to figure out if your missing spark at the plgs,or check fuel pressure at fuel rail,you'll need at least 55psi of fuel pressure,but if you have had no luck spraying the throttle body,your probably missing spark
Jan 06, 2010 | 1999 Cadillac DeVille
Wont start getting fire and fuel it just runs over til the batter dies
ok since you didn't give alot of information like the year and the engine
i'm going to assume that it is fuel injected
i know you said it is getting fuel did you check the fuel pressure
i know you said it has fire did you use a spark tester it may have spark but not enough to fire a spark tester
and if all that is ok fuel pressure and it will fire a spark tester then check the compression
next time the more information you can give the better chance we have of helping you
Nov 11, 2009 | GMC Yukon Cars & Trucks
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
