Question about Apple iPhone 5
Iphone5 has rotation problem. It appears to be unlocked but still does not rotate. How can I get it to rotate/
Rotation is turned on in control center but it still does not rotate
  • Apple Master
  • 3,368 Answers
Turn it off and wait a moment and turn it on. Some of the recent updates have caused interesting problems.
Posted on Nov 19, 2014
How do I unlock the screen rotation
if you use iOS 7 or 8, swipe up from the bottom to bring up the menu. ON the top row of icons, on the farthest right there is an icon with a lock surrounded by a circular line and arrow. Tap this to toggle the rotation lock on and off.
Feb 24, 2015 | Apple iPhone 5c
How do i get my tablet screento rotate
What type of tablet? If it's an iPad this is available a few different ways.
If it's an iPad 1 running on iOS5:
1. Check the little toggle switch on the side, depending on your settings this functions as both a mute and a rotation lock. Try changing this.
2. If your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Double click the home button and when the little menu pops up swipe right on it, you should see an option to lock/unlock the rotation.
If you are on a newer iPad
2. f your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Swipe up from the bottom of the screen to access the control panel. The screen lock/unlock option is directly on the control panel.
Dec 11, 2014 | Tablets & eReaders
Iphone5 will not rotate but the rotation is turned on in control center. How can I get it to rotate/
First try turning rotate off and turning the phone off and restarting, then turning rotate on again. If that doesn't make it rotate, reboot your phone (Hold power and function buttons simultaneously until it shuts down) and restart it. If that still doesn't fix the rotate function, you might have to backup and restore your phone.
Apple has detailed instructions on their web site for doing a restore for your version of iOS. Just go to http://www.apple.com/support/iphone/ and click on iPhone Essentials.
Nov 18, 2014 | Apple iPhone Cell Phones
My FaceTime screen is at 90 degrees
  1. Verify that screen rotation lock is off. If you see this symbol in the status bar, rotation lock is on: lock_rotate.png Follow the steps below to turn off screen rotation lock.
    • Swipe up along the bottom of the screen to display Control Center (you can do this from any screen, including the Lock screen).
    • Tap the Screen Rotation Lock button.
    • If the button was highlighted, the button will appear dimmed after tapping it.
  2. Not all iOS apps are designed to rotate. Some may use only portrait or landscape mode, or switch depending on the content. To test screen rotation, open the Calculator app that comes with your device. If the screen does not rotate as expected while using the calculator app, continue troubleshooting.
  3. If the issue persists, restart your iOS device.
  4. If the screen remains locked, back up and restore your device.
Oct 05, 2014 | Apple Ipad I-pad
IPad screen will not rotate. NOT locked, restart and reboot completed. Stuck in Vertical and running iOS version 6.1. Any solutions?
If u swipe from the bottom up, to get to the control center (or go to settings), is the orientation locked, or unlocked?
Jul 14, 2017 | Apple iPad (16 GB) WiFi Tablet PC
Its a lock with an arrow circal round it near the battery icon
You phone has it's screen rotation locked so if you turn the phone on it's side the display does not automatically turn, great for reading in bed. Double clicking your home button so that currently running apps are shown then keep swiping these icons to the right until your iPod controls appear, you should see an icon with a circular arrow. Click this.
Feb 28, 2011 | Apple iPhone 3GS Black (16 GB)
How do you unlock the rotation on an iPad? I've looked it up and I'm told the switch above the volume control turns it off and on, but on my iPad it just turns the volume off and on.
Use the following steps to enable screen rotation lock:
  1. Rotate iPad so the display is in the desired orientation.
  2. Double-click the Home button to display recently used apps.
  3. Flick from left to right along the bottom of the screen.
  4. Tap the rotation lock button on the bottom left of the screen.
  5. A padlock will appear in the rotation lock button.
Dec 28, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Whirlpool Duet Washer drum won't rotate, can't rotate manually
How are ya? This is kind of technical information that i'm about to give you, so if you're not that technical then you should call a service technician to diagnose. Good luck and thanks for the inquiry :)
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Aug 08, 2009 | Whirlpool WFW9200S Front Load Washer
My display has rotated and I can't fix it
go to control panel if you are using nvidia there should be an Nvidia control panel icon double click on that, click the plus next to display then click on rotate and make sure it is set to no rotation.
May 17, 2009 | Acer AL1715 17" LCD Monitor
Monitor control lock problem
Replace the small 78L05 regulator 5V supply to micro.
Jan 13, 2008 | Computers & Internet
Apple iPhone 5 Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
