Question about Nikon Coolpix L810 16 Megapixel Digital Camera - Black
How do I get the lens to retract, its stuck?
Camera will turn on for a second but will not reset the lens. I had inadvertently turned on the camera with the lens cap still on. Lens is now stuck in the extended mode.
  • Nikon Master
  • 3,382 Answers
I would suggest taking it to the camera shop for repair. They are very touchy when trying a DYI repair.
Posted on Nov 19, 2014
3 Suggested Answers
  • 1212 Answers
SOURCE: stuck in AF-ILL ONLY mode
Is the flash still on the camera when you do this? If so, check your camera settings as well as the camera may be over-riding you.
If the flash is not on the camera, some of the settings for custom settings can only be changed with it on the camera via camera commands.
If you do not have the manuals, you can get them here:
http://www.nikonusa.com/pdf/manuals/Speedlights/SB-800.pdf
http://www.nikonusa.com/pdf/SB800_techniques.pdf
Posted on Feb 20, 2012
MNfisherman
  • 11896 Answers
SOURCE: getting error message
This is an error due to programming of the camera. The lens is either sticking or not open fully as it should causing the camera to think the lens isn't open at all. I would try to download an update for your camera's software or have it sent in and upgraded.
Posted on Jun 10, 2012
The lens will not retract or close, when hooked up to usb connect camera just turns off, when turning camera on error message to camera on and off again is shown. I have gone in and reset/initialized it,...
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Dec 20, 2010 | Sony Cybershot DSCW370 Digital Camera
My lens does not retract when i turn the power off. When i turn it on again the message 'turn power off then on again' keeps coming. what can i do
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Dec 13, 2010 | Sony Cyber-shot DSC-H10/B Digital Camera
Not focusing, picture is blurry, lens goes in and out, tells me to turn on and off
This seems to happen when the Lens unit in the Camera is stuck and not retracting. The possible troubleshooting steps to resolve this issue are power resetting and factory resetting.
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset:(This can be performed only if the Menu of the Camera is accessible)
To reset the Camera, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.
Home-->Settings-->Setup 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Turn the power off and on again message
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Polaroid i735 Camera won't turn on. Lens stuck.
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
Digimax 430 camera won't turn on
If your lens is open and the camera turns off after those dreaded beeps, I have a fix for your problem. Basically, for this model of camera, the lens first pushes out a bit and then it retracts into the camera. Well, my lens got stuck on the pushout and it prevented the camera from turning on. I used some finger pressure and wiggled the lens a bit. Then I turned it on and it retracted to where is was supposed to be to take pictures. Then I turned it off and it retracted into the camera. Problem solved!
Nov 05, 2007 | Samsung Digimax 430 Digital Camera
Nikon Coolpix L810 16 Megapixel Digital Camera - Black Logo
106 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
