Question about Ricoh Office Equipment & Supplies
How do i turn my printer on the start button is not working and i have checked all my plugs im just wondering if there is maybe like a switch or something?
  • Ricoh Master
  • 3,368 Answers
Check and be sure it is plugged into a good outlet. Sometimes plug strips get turned off and you do not notice it.
Posted on Nov 19, 2014
Hello,my 1983 ford ranger doesn't start it does smell like gas when im cranking it over .ive had rebilut carb,cap rotor ,has good spark on new plugs ,new fuel pump,new filter and carb is getting gas.im...
That solenoid is the electric choke and it will flood the truck out if it's not working properly, have you tried to hold the butterfly opened while cranking it, if it starts then, you can unplug the connector to the choke and run it, it just might be hard to start when it's cold.
Nov 10, 2014 | 1983 Ford Ranger
I have an older model Timberwolf 4-wheeler, i believe it to be a 250 maybe. It says 1500 cm^3 on the engine, but I know its not 1500 cc, so maybe that is 150 cc? Anyway, the engine turns over great, but...
1500cc is the oil volumne
the engine size is often caste into the barrel under the carb.
sounds like a fuse is gone, there is probably a cut out circuit involving the clutch lever and neutral light, so that it cant start in gear and run over anyone.
check all the wiring plugs.
Aug 13, 2011 | Yamaha XT250X Motorcycles
Replaced starter and wont start. Im wondering if it is the shut off switch in the trunk? does the switch have to be up or down?
the starter cranks the engine, the switch in the trunk has a button that you depress to reset the fuel pump. if the fuel pump doesnt operate then the switch may tripped, the button is DOWN. So does the engine crank? does it not crank? cranks but wont run? if it cranks but wont run, then check the switch in the trunk. Power goes to that switch and then to the pump, so if that switch has power going through it, and the pump doesnt work, the pump is bad. when turning the key on you should hear the pump go on for 2 seconds.
Dec 05, 2010 | 1999 Ford Taurus
Logitech Z-5300 Turns off and on by itself
Hi...
Im not sure if this will help u but check ur Remote's power botton.
Maybe its stuck?
It happened to me before... Was wondering y it turns itself on/off and found out later that the power botton on remote is stuck.
U should hear the clicking sound everytime u turn it on or off.
Otherwise... something else is wrong with the power switch on ur remote.
-Vash_Stepler
Sep 19, 2009 | Logitech Z-5300 Computer Speakers
Fan and compressor will not run
Try replacing the fuses for the condensor.
Apr 24, 2009 | Goodman CKL36AR36 Air Conditioner
86 corolla has no power on acceleration
I'd be tempted to pull cover off & check belt too, or a quick compression test, to see what it tells me.
Apr 16, 2009 | 1986 Toyota Corolla 2 Door
Printer wont switch on
hi im josh in cebu phils. may i help you friend? Friend such problem occurs when there is a shorted parts inside.it doesn't turn on for now because built I.C. of printer and pc has an auto shut off lever that automatically shuts of every-time time the board has an unusual problem especial short circuit. Friend  1.try to check the connections of the power chord be sure it is not shorted. 2.Check the power switch button of the printer maybe there's something stuck on it that makes the connection shorted or faulty. Good lcuk friend hope i helped you.
Mar 14, 2009 | Canon PIXMA MP760 All-In-One InkJet...
On/off button blinking
Did you check your particular models warning lights page? Maybe your head cleaner is full or the printer needs maintenance. Take a look at your printer manual to see what the warning lights signify. Sometimes printers reset if you remove the plug from the back then push the power button and plug it in again while your still pushing the power button. Then you can try turning it back on normally again...
Dec 09, 2007 | HP PSC 2410 All-In-One InkJet Printer
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
