Question about Car Audio & Video
My pioneer app radio won't boot up it starts ip then just turnd white how can I fix that
I need to pioneer carrozzeria avic-drz99 boot dvd
ELECTRORAMA TRINIDAD HAVE THE BOOT CD TO FIX IT, THEY ALSO CONVERT RADIO TO RECEIVE LOCAL FM STATIONS..PH # 662-6387...DANIEL / DAVID...
Sep 22, 2012 | Pioneer Gd-f1 Carrozzeria Am/fm Car Radio
Pioneer Carrozzeria AVIC-DRZ009
Electrorama Trinidad have the boot disk to fix it ...Ph. # 662-6387 ... David & Daniel .. also convert radio to receive local fm stations...
Aug 25, 2012 | Car Audio & Video
Pioneer car radio won't power on
check the fuse at the back of stereo , and the radio fuse under the dash or whatever
Jan 15, 2012 | Pioneer Car Audio & Video
What is the blue and white wire with the fuse for? Also i have a solid yellow wire what is that for?
the blue/white wire is to turn an amplifier on. If you have no amp, don't worry about it, Just make sure you cap it off so it won't touch anything as it is hot when the deck is on. The yellow wire is constant power and has to have power going to it even with the key off as it controls the memory of the radio (clock and radio presets).
Jul 07, 2011 | Pioneer DEH-P6700MP CD Player
I have a p2500 and its great. Can I connect my red and white audio cord attached to my ipod to the red/white jacks on back of radio? then listen thru aux?
Those cables are for audio out only you need an IP Bus adapter to connect the AUX input. the CDRB20 or CDRB10 is what you need. the CDRB20 allows for more inputs as well such as CD changers, and XM radio tuners.
Mar 13, 2011 | Pioneer DEH-P2500 CD Player
Front panel only lights up wen turnd on or adjusting ...after it turn s off
Need to press the fl dimmer button on the front panel it controls the display.
Jan 29, 2010 | Pioneer VSX-D409
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
Pioneer Inno Gex-INNO2BK stuck in re-boot cycle
I fixed the reboot cycleing problem by plugging the travel charger into the jack that also fits the home and car cradle. I had the Inno set to auto start when it was powered on in the car cradle. The travel plug must have over-ridden the auto-start setting and allowed it to finish the complete bootup. I then reset the Inno default settings and every thing was back to normal. I do not know what was the original cause of the rebooting cycle problem
Jul 28, 2008 | Pioneer inno2 Portable XM Satellite Radio...
Iphone
I had the same problem when i jail broke went through and fixed. Here is the Soulution to your proplem when you jailbreak your iphone it does a disable to your app store applications. you have to hold the icons to get them tot jiggle delet each one that you can and redownload they will work just fine after that.
Jul 27, 2008 | Apple iPhone Smartphone
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
