Question about Home Security
How to open a Honeywell A016 safe - Home Security
Tip
How to open a 2087d Honeywell safe if you lost the battery backup
Honeywell no longer sells the battery back up! I made my own by putting 4 AA Batteries in a series, found a USB cable that matches the plug on the safe door and cut the USB end off the wire. Strip the two wires Red and Black and put the red on the positive side and black on negative side plug it into the safe and put the combo in then turn the handle and open the safe. You can make a battery by going to an electronic store and tell them what you are looking for or if you have a toy at home that has 4 AA batteries you can wire it into that Temporarily open your safe and give the toy back to your kids. LOL
on Jan 11, 2017 | Honeywell Safes 2087 Waterproof Fire Safe...
Got old honeywell safe No:HWF19004340, no key and don't know combination. Can it be opened?
contact a locksmith for the answer to your problem All safes can be opened by professional trades people.
Apr 06, 2013 | Safe International Digital Electronic Safe...
I have forgotten the combination to my safe. Is there anyway to retrieve the combination?
Only way.Did u register the safe product when u buy this thing,yes call Honeywell.They will give u their secret master combination numbers if they trust u or they'll sent out to u a safe tech. service rep. to ur house used that combinations.
Jul 14, 2011 | Honeywell Safes 2087 Waterproof Fire Safe...
I have lost my key to my small honeywell safe. it is non digital. is there anyway to open it without damaging the safe lock?
hello strea..... take the safe to your local locksmith. be sure to have picture ID with you. J.
Mar 25, 2011 | Honeywell Home Security
I HAVE A HONEYWELL 2087D SAFE I CHANGED THE COM AND CANT REMEMBER WHAT I CHANGED IT TO. i CANT FIND THE MANUAL AND NEED TO FIND OUT HOW TO OPEN IT...
Hi I have the key and know the code , I want to change the code on my Honeywell 2087D I have lost the book what's the trick? I have no red reset button. Please HELP!!!! Sharon
Dec 01, 2010 | Honeywell Safes 2087 Waterproof Fire Safe...
My documents in my Honeywell safe are moldy and damp
Desiccant Moisture absorbing packs will help to absorb some of the excess humidity in the safe. In addition to the desiccant packs, you should open the safe at least once every two weeks for approximately 20 minutes. To alleviate some of the musty odor, we suggest that you remove the items from the safe and wipe the interior with a paste of baking soda and water. Do not store your safe unit in areas of your home or business with already high humidity levels such as a basement or cellar as this will add to the moisture problems. You can purchase desiccant packs from www.SentrySafeShop.com . The link for the desiccant packs is: http://www.sentrysafeshop.com/Moisture-Control-Desiccant-Packets-p/desiccant%20pack.htm
May 10, 2010 | Honeywell 1070 cu in. Waterproof Firesafe
Home Security Logo
57 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
