Why my video memory turn into n/a - Computers & Internet
    Sergeant:
  • 192 Answers
Usually, this happens when the wrong drivers are loaded for the card, even though it does work. Check to make sure that you have the latest drivers for the specific card you have. From the screen shot you attached, it looks like you have the generic VGA drivers loaded, not one specific to your card.
Posted on Nov 18, 2014
Asus p5n-mx video adapter error
The video adapter uses shared memory. It very well could be the cause of the second POST code.
Aug 25, 2014 | Computers & Internet
My monitor turns on with a green light and then immediately changes to a yellow light
Sounds like you have no video output from the motherboard. Unplug your desktop computer from the wall so no power is going thru it. Take out all the memory sticks from the slots. Then go ahead and reseat one of them in any slot. Then with the Monitor hooked up turn on the computer. If you still don't get video then repeat the steps and try the memory in each other slot.
If you have more then one memory stick try each one in each slot. If you still have no video after trying all the slots with each different memory stick then that means the motherboard is bad.
If you have a external video card that was installed then take that out and use the internal one that your motherboard came with and swap out the memory using that.
Basically your turning off the computer swapping memory out in each slot and turning the computer back on to see if you get video to come back on.
Feb 05, 2012 | IBM Aptiva E 500 (2158500) PC Desktop
I get continious beeping in my computer with no display
No beeps Short, no power, bad CPU or motherboard, or the CPU is not installed properly. One long beep, then two short beeps Video problem Continuous hi-lo beeps CPU overheating Repeated long beeps Memory error All other beeps Memory related error
If you are getting hi lo beeps, refit CPU and heatsink
If continuous long beeps, check memory is seated correctly, if more than 1 stick, try each one on its own, 1 may be faulty, or incompatable
Aug 23, 2010 | Foxconn 45CMX socket LGA775 motherboard...
Continuous Beep-Beep-Beep.. When I turn on T3304 E Machine
there is a faulty hardware in your PC. here the beep error code this might help to locate the faulty hardware in your pc, and which help you to isolate the problem.
1 Short beep - System is operating normally.
1 Long beep - Memory refresh circuitry has failed which indicates a problem with the motherboard. Try
reseating the memory DIMM or SIMM modules. Make sure if you have added memory that it is rated at the correct speed for the system.
1 Long 2 Short beeps - The video adapter has failed, or the video memory is having a read/write
failure. Try reseating the video card. If the video card is a PCI video card, try moving it to another slot.
1 Long 3 Short beeps - The system does not detect a monitor. Verify that the monitor cable is properly attached to the video card or the onboard video and to the monitor (if the monitor has a detachable cable). If possible, try another monitor on the system to verify that the video adapter is operating properly.
2 or 3 beeps - There is a problem with the system’s memory. Reseat the memory DIMM or SIMM modules.
4 beeps - This indicates a non-functional timer. This indicates a problem with the motherboard.
5 beeps - This indicates a CPU (Central Processing Unit or processor) failure. Try reseating the processor.
6 beeps - This indicates a keyboard controller failure. Try reseating the keyboard connector.
7 beeps - Another indication of a processor problem. Reseat the processor.
8 beeps - This indicates a video memory read/write failure. Reseat the video card (if any) and memory DIMM or SIMM modules.
9 or 10 beeps - This indicates a ROM (Read-Only Memory) checksum error or shutdown register failure. This indicates a defective BIOS chip(s). Reseat the BIOS chips.
11 beeps - Indicates an error in the cache memory. If the system has a Pentium class processor, reseat the processor. If the system has a cache memory module, try reseating it. These beep codes will vary depending on the system
hope this would help.
Nov 30, 2008 | E-Machines eMachines Desktop PC
How to capture video and save in memory stick
turn on the camera and switch to video mode and, on settings(options or something) you will find save to phone memory or memory stick. choose memory stick
Jul 18, 2008 | Sony Ericsson K800i Cellular Phone
Long beep!!!!
u clean the memory card & memory slot as well as video card.
u can clean the memory card using pencil rubber. u clean near ram connectivity(it looks like gold colour track connectivity both the side of the memory card)
if u have any problem send me the details
Feb 27, 2008 | EPoX EP-4PLAI Motherboard
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Camcorder says my memory card is missing
Turn on your camcorger, push the button menu. Select the rec media for video, select hdd so that it looks for the hard drive, Mine defaulted to the sd and was also looking for the memory card. Missed filming my son's 6th graduaton because of that!!!
Hope this helps
Jan 31, 2008 | JVC Everio GZ-MG130 Camcorder
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
