Question about Panasonic TCP50S30 50 50 Plasma TV
Power button on TV won't turn TV on or off but the remote will.
    Sergeant:
  • 192 Answers
Either the power switch on the TV is broken or jammed. If you have electronics cleaner (not WD40, it has to be designed for electronics) you can pray that into the switch opening and see if it clears it up.
At least you can use the TV with the remote.
Posted on Nov 18, 2014
Testimonial: "I already replaced the keyboard, no change."
The Vizio TV won't turn on all of a sudden
Are you trying with the remote and the power button on the tv? The batteries might be dead in your remote if you haven't tried the power button on the TV.
Feb 15, 2013 | Televison & Video
Zenith a27b41w won't turn on. It just clicks whether using the remote or the button on the tv
Probably a power supply problem. The click could be a relay closing
Nov 04, 2012 | Televison & Video
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
My RCA P60925BL won't turn on with remote or using the power button
Try by an other code for your device from the code list for your tV brand.
Jun 08, 2012 | RCA Televison & Video
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Won't program to our new TCL television - we have the 222 receiver
I don't show we have a code for the TCL (Australia) brand TV. Below I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the red TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 14, 2011 | DISH Network IR Remote Control
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
Jun 12, 2011 | DISH Network IR Remote Control
Panasonic TCP50S30 50 50 Plasma TV Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
