Question about Brother LB6800 Project Runway Sewing/ Embroidery Machine w/Bonus Rolling Tote & Thread packs LB6800 Bundle Project Runway Sewing/Embroidery Machine w/Se
I have a LB6800PRW how do I sew thru several layers of fabric. I am trying to go thru the top fabric, 2 insulbrite layers and bias tape. Needle jumps up and down and won't go thru. I am using
Changed needle to denim #16 and 18 increased stitch length to 5.I am making pot holder for cast iron skillets using 2 layers of cotton fabric, 2 layers of insulbrite fabric and the bias tape.
  • 11 Answers
SOURCE: How do I fix thumping/clunking sound?
make sure your needle is facing the right way, some needles if you look at the front and back you will see a groove side and a flat side sometimes it is hard to tell the difference depending on needle style.. hold it up to light and look at it from the side the difference will be slight but you will see a difference groove should face the back or if your presser foot is out of wack (lol so technical terminology) it could cause needle breaks and noise you can detect damage to the presser foot if this is happening.... only other thing i can suggest is to make sure bobbin is securely snapped into the housing if not it can cause problems with the needle picking up the bobbin
Posted on Apr 08, 2010
  • 415 Answers
SOURCE: I get skipped stitches when
Did you use a larger sized needle for the think fabric? It sounds like the needle isn't penitrating deep enough. You will need a larger needle size for the thick fabric and you might try slightly adjusting the tension tho a larger needle may be all you need. Make sure it is a sharp not a ballpt needle too (assuming you're not using polyester knits which isn't something one usually makes oven mitts with :) )
Posted on Mar 21, 2011
Testimonial: "Very pleased!!!!!!"
SOURCE: Skip stitches
some machine are not made to sew thick or heavy fabric
Sewing machine skips stitches
needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Posted on Sep 04, 2012
  • 13 Answers
SOURCE: Uneven feed
machines can have single or double feeders. what type does yours have? feeding problems can usually be fixed by a good cleaning+ oiling of the feeder mechanism which regularly gets clogged with lint+threads/scrap threads. brush it out thoroughly with a stiff-bristled brush like an acid brush. apply 1 drop of oil to each feeder seen on the foot-plate. wipe excess oil off with a clean dry rag being sure not to get any debris from the rag caught in the feeder(s). other problem might be your bobbin tension. this is usually adjusted on the bobbin race with a very small screwdriver.
Posted on Feb 22, 2014
99rannellis
  • 9497 Answers
SOURCE: Why do stitches bunch when using walking foot on 3 layers of quilting fabric?
Your machine most likely has a presser foot pressure control. Check your owner's manual. Perhaps the pressure on your machine is set for light-weight fabric and, as a result, is pressing too firmly on your quilt sandwich. Decrease the pressure and see if the walking foot performs better. You should not have to pull the fabric through your machine.
Posted on May 10, 2015
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
I get skipped stitches when I use my decorative stitch #27 and ZigZag stitch sewing heavy layers of fabric. I have changed my needle, cleaned out the machine and sew very slowly; basically I have done...
Mar 21, 2011 | Brother InnovIs QC1000 Electronic Sewing...
New sewing machine is squeaking
YOu may have bent the needle. Put in a new needle and re-thread the whole machine. See if that works.
Jun 28, 2010 | Husqvarna Viking 1
I am sewing through 4 layers of fabric and the needle isn't going through and catching the bobbin thread. What should I adjust? It was working fine through 2 layers of fabric.
The reason it is not sewing is because when the needle goes through the 4 layers of fabric the thread from the needle is not abloe to form a loop for the hook to catch, try turn the tension down a bit.
Apr 21, 2010 | Sewing Machines
I WAS SEWING THROUGH SEVERAL LAYERS OF FABRIC MY
Refer to the manual. If there isn't any information there. Call your Janome dealer and ask to speak with the service person.
Mar 10, 2010 | Janome Memory Craft 9000 Computerized...
The thread on the bottom skips stiches and is coming thru to the top
Here are several solutions to try.
* Re-thread your needle It may be threaded incorrectly (backwards).
* Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly. Usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
* Change your needle it may be bent, or otherwise damaged. Make sure your needle is appropriate for the type of thread you’re using.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
* Adjust the pressure of your pressure foot as it may be too light for your fabric.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Adjust your thread tension as it may be too tight or too loose.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Note: After changing your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps
Dec 29, 2009 | Singer 1725
I'm sewing metallic fabric and the needle keeps gumming up and then the thread breaks.
Hi, What you need to get is a bottle of Sewers Aid . It is made by Prym. The best way to use it is, spread an even layer up and down the spool of thread. When that section of thread passes thru the needle it will lubricate to enable the needle to pass thru the fabric with greater ease.
May 06, 2009 | Sewing Machines
Consew 206rb bending needle
I have three possible solutions:
1. If sewing on heavy fabric or thru several layers, change needle to a larger size.
2. Make sure to let the fabric feed by itself, don't pull on it.
3. Make sure the upper thread is not catching on something (like the end of the spool), this will cause the needle to bend and break.
good luck!
Jan 30, 2009 | Consew 206RB
Machine skips stitches when sewing thru several layers of fabrics
Is your needle new? The needle needs to be replaced every 8 hours on a regular sewing machine, and the ULT benefits from even more frequent changes. Also try a bigger needle, if you're using a 75/11 move to a 90/14, make sure your needle matches what you're doing, you might not think those little needle tips differ much but they really do.
The manual also mentions if there is to much lint under the needle plate. Keep in mind all sewing machines need the bobbin area cleaned out every time you change the bobbin, but the ULT likes cleaning up down there about twice as often.
Oct 08, 2008 | Brother ULT2001
Brother LB6800 Project Runway Sewing/ Embroidery Machine w/Bonus Rolling Tote & Thread packs LB6800 Bundle Project Runway Sewing/Embroidery Machine w/Se Logo
Top Brother Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Brother Tool and Hardware - Other Expert? Answer questions, earn points and help others
