Question about Shredder Office Equipment & Supplies
Ho do I remove the shredder to clean it
Everything I don't know how to disconnect the shreeder part
    Problem Solver:
  • 12 Answers
Give me more information... What kind of shredder is it?
Posted on Nov 23, 2014
Do you need both lub. sheets & lub. oil for a shreeder ?
I would suggest something light like sewing machine oil. Vegetable oil is likely to go sticky.
Jul 05, 2015 | Office Equipment & Supplies
P-45c shreeder motor runs but blades do not turn got all paper out but still do not turn
David,
More than likely, you have stripped the plastic gear inside. Those gears can sometimes be difficult to find and purchase. I would suggest trying to open up the top so that you can confirm if the gear is stripped. I would also suggest not putting as much paper through the shredder as they say it will handle. Hope this helps!
May 20, 2015 | Fellowes Office Equipment & Supplies
How do you clean the jammed paper so it will work?
I'm thinking that you have already run the shredder in reverse, right? After you disconnect from power supply and remove screws, most shredders can be disassembled quite easily. Be careful with the cutting blades, not only are they sharp but they have a preferred order in assembly. I give my crosscut shredder a good cleaning about every two years, having run about 5,000 documents with personal data on them through it in that time.
Sep 19, 2014 | Office Equipment & Supplies
Power on and shreeder will not run. Is there a reset button?
there could be a thermal switch in the motor that is open cct check with a meter if you get continuity on motor wires
Feb 20, 2011 | OfficeMax 0M96431 Shredder
How do you rotate shredder blades on duerr m/n 678?
Interesting question --
I just picked up one of these over the weekend, and was able to get the flywheel off with minimal excitement. After removing the center bolt from the flywheel, I used a hammer to "encourage" the flywheel off the keyed shaft from the back-- through branch feed hole in the housing. It took quite some time, and I rotated the flywheel as I did it to keep it from binding up, but it eventually came off.
As an aside, would you let me know if you've found any source for parts or documentation? I'm going to attempt some repairs on the flywheel and chipper blades, but may end up wanting to replace them.
Apr 07, 2010 | Heavy Machinery
Shreeder Feeder jammed , appears cleared, makes a humming noise when attempting to feed paper and a similar noise when hitting the reverse button. Help please. Thank you.
It could be one of two problems and they are both usually caused by over feeding. Either the tooth rollers have junped out of their sockets or they are jammed tight with paper which would cause the first to happen also. There are safety switches but unplug the unit any way. Get on the output side of the shreeder and start pulling paper or remove the metal object that was dropped into its throat. Hopefully, you won't have to take it apart to put the rollers back into their sockets.
May 28, 2009 | Office Equipment & Supplies
Royal ht 500 x shredder
When I recieved your reply to check the micro switch I found the contacts had built up a little
arcing on the points, I then filed the points and cleaned them with alcohol and put it back together
It works like new. If it bothers again i may try to get a new switch for it I owe you a large thanks
for the info to fix my problem
Sincerly Joe Gese
Jan 07, 2009 | Adler Royal HT500X Shredder
Shreeder broken
Here you go buddy http://www.fellowes.com/Fellowes/Materials/Documents/ps60-2_60c-2_2005manual.pdf
Jun 20, 2007 | Fellowes PS60-2 Shredder
48 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
Gilbert Ruiz
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
