Question about Denon Dvd Home Theater System Remote Control Rc-902 Dht-700dv Adv-700
Ho do I open a Denon remote control unit
Removed the screw in the battery compartment
  • 139 Answers
Make sure there are no hidden screws , top and bottom of remote snap together, usually top snaps over bottom so you have to slide something between halves and push in on bottom or pull out on top to get them to seperate.
Posted on Nov 26, 2014
HOW CAN I OPEN UP A REMOTE CONTROL UNIT / MAGNAVOX - NC003UD TO CLEAN IT
Check inside the battery compartment and feel over any labels, there may be screws there that need to be removed before it will come apart. If no screws then there will be snap clips around the outer edges of the case, but inside so you don't know exactly where they are located. To get it apart use something like a credit card push it in between the 2 halves of the housing and slowly work it around, in and out until you find where the snaps are located, then use the card to carefully slide the snaps apart. Good luck...the snaps do tend to breal easily.
Aug 13, 2014 | Magnavox NC003 Remote Control NC003UD
How do I free up the volume control that is sticking?
Take controller apart by undoing screw inside battery compartment and then prise apart starting at battery end using a flat head screwdriver. It is not glued together so with a little effort it will come apart. clean all components especially behind the rubber buttons and on top of the circuit board, then put back together. I had to cut the rubber buttons into sections removing a small slither because the rubber seemed tho have stretched and would not sit flat. Now controller works like new.
Apr 28, 2014 | Denon Televison & Video
Rmt d231p
There are no hidden screws. If there is, it should be inside its battery compartment.
May 21, 2013 | Sony RMT-D Remote Control
Remote control for vmb070 does not work
There should be a clear indication on your remote where the battery compartment is. Usually there is a slideoff cover that has to be removed. Some remotes have covers that are difficult to remove. Once you have the compartment open, you can remove the batteries. Check for signs of corrosion inside the compartment and clean it before installing new batteries. Be sure to observe proper polarity when installing new batteries
Mar 17, 2013 | Televison & Video
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
(I) spilled milk in my Denon RC-802 audio/video remote control. How do I get it open to clean it without damaging it?
You can find replacement remotes at places like this:
Replacement Remotes
As for cleaning it, most remote controls have TWO different ways of fastening the two halves together. The first is screws. Open the batter compartment and remove the batteries. You may find one or more screws there. Remove the screws and set them aside in a safe place. Sometimes the screws are under labels on the back (the screws are almost always on the back side of the remote). Unfortunately, after you remove the screws, the remote may not open. This is because it is usually also held together by plastic snap tabs. Each remote is different, but the method used is always the same: you take a very thin metal blade, like the edge of a putty knife, and move it along the groove separating the front and back halves of the remote until you feel a "bump" of some sort. Press in firmly on this bump while at the same time torquing the blade to separate the two halves. You will have to do this for each latch, making sure the previous latch you undid doesn't click back in place. You will probably end up marring the edge of the remote a little bit while you do this, but that is unavoidable.
Jan 25, 2011 | Audio Players & Recorders
How do I remove the back of the remote control for a Sony TV? The model number is RM-ED002. I have located two small screws in the battery compartment but removing them doesn't seem to be enough to do the...
The two screws inside the battery compartment would not really hold the case together. Try using two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous.
Aug 22, 2010 | Sony RM-Y132 Remote Control
How to open remote control Sony RM-Y181
There should be small screws (usually phillips head) at either the top, bottom or both ends of the back of the remote. Unscrew those and pry loose. If not, they will be under the batteries, inside the battery cover.
I assume that's what you mean by open?
:D
Aug 10, 2009 | Televison & Video
Disassemble DirecTV RC32 remote to fix sticky buttons
There are a total of SIX screws. You have already found two in the battery compartment. There are four more under the GREY panel on the front of the remote. That grey panel pries out; there are two tabs on the lower sides and one on the top, above the > button, that hold it in. Should not be hard to get it out to reveal the four screws. Take them all out, and the remove easily pries apart for service access.
Feb 05, 2009 | Directv RC32RFK Remote Control
Denon Dvd Home Theater System Remote Control Rc-902 Dht-700dv Adv-700 Logo
149 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
