I have a Lennox 51M34 Merit Series programmable thermostat. It's currently set to 68 degrees, but it's maintaining a constant 64 degrees (as if that's what it's set to). The furnace comes on and goe
I have a Lennox 51M34 Merit Series programmable thermostat. It's currently set to 68 degrees, but it's maintaining a constant 64 degrees (as if that's what it's set to). The furnace comes on and goes off just like it's set to 64 degrees (it's not constantly running), even though it's actually set to 68 degrees. Setting it anything else (like 70 degrees) doesn't change anything--it wants to maintain a constant 64 degrees. Is this something that can be fixed/adjusted? Or does it sound like I need to replace the thermostat? Thanks!
Sea Breeze
  • 4654 Answers
SOURCE: Runs constantly to maintain 40 degrees, requires highest setting
Not sure how old it may be, but you can check a few things to see if it's defrosting properly. Also clean the condenser coils under the refrigerator to insure good circulation of air over coils. In the picture below you will need to check out three things until we find the problem. Defrost timer, defrost heater, and defrost thermostat. Let me know when your ready, Sea Breeze
seabreezehvac@yahoo.com
Posted on Apr 20, 2009
SOURCE: Lennox merit series furnace is not kicking on
I have the same issue with a G21Q4-5-100-1 model lennox. House drops 8 - 10 degrees. I have 3 thermostats and all react the same way. I was told by service tech that the Ignition Coontrol Module is bad and acting intermittanely. ???
Posted on Feb 16, 2010
roniecon
  • 6826 Answers
SOURCE: temp setting way off kenmore 580
Remove the window unit and dissasemble,and clean it out,careful not to bend the fins on the condense and evaporator,but clean them out,and the inside of the unit also,then see what happens,if the problem persist,then find the probe on the evaporator and move it away from the evaporator until the compressor stays on longer.
Posted on May 27, 2010
kapishtech
  • 2272 Answers
SOURCE: Honeywell thermostat; Lennox elite series
When the furnace exceeds the temperature set by the thermostat, this could be indicative of several issues. The thermostat mounted crooked. When a thermostat isn't level on the wall, it can affect the automatic on/off function. To fix this problem, pop the cover off of the thermostat and loosen the screws attaching it to the wall. Straighten the device and tighten the screws.
If the thermostat is level and the temperature regulation system is still malfunctioning, the problem is most likely with the heat anticipator setting. The heat anticipator is a device inside the thermostat that governs when the furnace turns off. When the heat anticipator is on the fritz the furnace doesn't receive accurate direction, resulting in a heat system that either runs too long or not long enough. Usually, simply adjusting the heat anticipator, which is a small disc located underneath the thermostat cover, will fix this problem.
  • Temperature Does Not Reach or Exceeds Setting
  1. Thermostat is not level ? Use a level to realign thermostat.
  2. Anticipator not set correctly ? Adjust the anticipator.
  3. Thermostat not calibrated ? Recalibrate line voltage or low voltage thermostat.
  4. Range stop incorrect ? Clean thermostat and check .if same problem then,Replace thermostat.
  5. To clean thermostat.
  • Kill the power at the circuit breaker panel.
  • Remove the thermostat cover.
  • Clean the bimetal coil with a soft, clean brush.
  • Remove the thermostat body by unscrewing the retaining screws (on a round thermostat). Slide a piece of bond paper between the lever and contacts to clean them.
  • Reassemble the thermostat.
  • Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
    Posted on Sep 21, 2010
    shastalaker7
    • 1515 Answers
    SOURCE: Our Honeywell programmable thermostat is
    Good Morning, and yes you said it. Anytime a stat doesn't come on when it is set for a call for heat or cooling, the sensor on the subbase of the stat has lost its ability to sense the correct temperature. I have seen mechanical stats last as long as 25 plus years, but that's truly amazing for a digital stat to last that long. Yes, replace the thermostat. I don't know what kind of system you have, but if its a gas furnace with an a/c, the wiring will look like this. You will have terminals marked R, Red, for the 24 volt hot wire, G, Green, Y, Yellow, and W, White for heat. Going back to the red wire, it should have RC and RH on it. There will be a normally red wire connecting the 2 terminals.The Red wire coming in can connect to either one, as they are all together. The new stat will come with the new Red jumper wire attached. So, if you do have a gas heater, this is very easy to install. The only terminals you will need to use are RH to RC for the incoming red, Y, G, and W for heat. Y is for cool, and G is for fan. Very easy. Now if you have a heat-pump, they have many more terminals and can be a problem wiring them. If you have gas, forget the heat pump. I wont confuse you by going there. If it is a heat-pump, contact me in the comment box to let me know, and I can help you there also. Get a new stat at Home Depot, Lowe's Hardware, or O.S. Hardware. You want a 5 day, 2 day programmable Heating and cooling thermostat, 24 volts.It will have everything you need. See if it takes batteries for the display, they may not come with those, it will say on the box. Turn off your power to heater, so you won't short out the new one.They come in 2 sections, first the stat that just snaps on, and the subbase that is screwed to the wall. It will have the wiring terminals on it. Remove a couple of screws and loosen wires and remove. Be sure you write down how the wires go in case they used different colors, you never know. You will be all set. Store the manual in a safe place for future use. I wish you the best.
    Shastalaker7
    A/C, Heating, & Refrigeration Contractor.
    PS, Please rate me on this :))
    Happy Holidays to you and family!
    Posted on Nov 23, 2010
    Testimonial: "I hate spending money needlessly replacing items that may not be the problem. Thank you for confirming my suspicions."
    My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
    Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
    Dec 28, 2016 | Heating & Cooling
    I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
    Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
    If the temps are both the same, the furnace thermostat is fine.
    If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
    Feb 09, 2011 | Heating & Cooling
    Lennox merit series furnace is not kicking on until house is 8 to 10 degrees colder then set thermostat
    Jan 31, 2010 | Dayton Gas Furnace Heater
    I set my thermostat to 68 degrees. it stays there for a while then for some reason the temperature drops to 60 degrees?
    check your reset button and if that does not work take off the plate and manually reset your thermostat.
    Dec 31, 2009 | Hunter Fan Company 5/1/1 Programmable...
    I have just had a new boiler fitted and wanted to run the thermostat (honeywell cm921) on auto, the electrician set the timer to come on at 1 & off at 2 disabled at 3 & 4 and on again at 5 and off...
    Complicated because I need more info....but in General a Boiler should not be on a Programmable Thermostat as it takes too long to heat etc...do you have Radiators in your house???Or ductwork for heat???It will make a difference...if you put the boiler on a program it may come on anyway as some boilers maintain there own internal temperature regardless of the thermostat.....if you want to run it on a program adjust the temperatures so there is only about a 2 degree swing....70...down to 68....back to 70.....etc...there should also be a switch in the thermostat to set for Boiler...or Electric heat...make sure that switch is on...otherwise its difficult to give you a more conclusive answer
    Nov 11, 2009 | Honeywell Programmable Thermostat Heater
    Forced Hot Air Heating system doesn't maintain thermostat setting
    It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
    Good luck, hope this helps.
    Matt
    Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
    Thermostat
    I have a Honeywell Programmable Thermostat, T8011R. The users guide for the T8000 series can be found at:
    http://www.honeywell.com.au/business/acs/acp/ecc/ec/residential/identify.html
    To keep your temperature at a single setting, just enter the temperature at every period, i.e. WAKE, LEAVE, RETURN AND SLEEP for both the Monday through Friday time frame and the same for the weekend. I do this at 55 degrees when I'm going to be out of town.
    To 'Guest' , enter your 68 degrees at WAKE, LEAVE and RETURN, then enter 66 degrees at SLEEP. Do this for the Monday through Friday time frame and again for the Saturday - Sunday time frame.
    Dec 19, 2007 | Honeywell Programmable Thermostat Heater
    Heating & Cooling Logo
    172 people viewed this question
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
