Question about Foremost Home
I have a foremost Model T-7600-HET low flush toilet. The toilet seat has lost one of the bumper stops. I cannot find a replacement, so are they available from the manufacturer. The only other choice i
I have a foremost Model T-7600-HET low flush toilet. The toilet seat has lost one of the bumper stops. I cannot find a replacement, so are they available from the manufacturer. The only other choice is to buy a new seat. That should not be required in a time line of less than 2 years.
  • 3,368 Answers
A replacement sounds like the most echnomical solution in the long term
Posted on Nov 19, 2014
djchillsnyc
  • 152 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
kachbibi1
  • 979 Answers
SOURCE: Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Posted on Jan 28, 2009
dragonsthatk
  • 547 Answers
SOURCE: Jacuzzi Whirlpool toilet EZ33959
any one should fit
Posted on Feb 21, 2009
SOURCE: Kohler 81100 Pressure-Clean Flushometer Toilet
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Posted on Apr 21, 2009
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
Foremost toilet slow draining. cant plunge, cant snake.
It sounds like the waste pipe is clogged or has nowhere to drain to
Jan 09, 2014 | Foremost Home
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Delta Home
Uberhaus dual flush toilet keeps running
The flapper may not be seating properly after a flush. Even though you say the toilets are brand new, something may be askew in the flushing assembly or may have been affected during installation
May 27, 2013 | Home
WHERE CAN I GET REPLACEMENT SEAT AND COVER BUMPERS FOR MY BEMIS TOILET SEAT?
If the seat is a molded wood seat, you can usually get bumpers by contacting Bemis Customer Service, 920-467-4621. The bumpers on plastic seats are not replaceable because they are part of the seat.
Mar 26, 2011 | Bemis CHURCH Elongated White Slow Close...
Toilet loosing water in tank. Makes little hissing noise.
the little hissing noise is probably the valve slowly filling the tank back up and the water leaking out is probably because the flapper ball needs replaced. You can see it and get to it and replace it very easily, it is the black ball in the bottom of the tank, it has a chain going from it to the flush handle.
First make sure the chain has not flipped over the handle or gotten twisted, I have seen this happen and it does not allow the flapper ball to go all the way down and seat.
If you rub you finger across the top of the flapper ball and black (deteriorated rubber) comes off then replace the flapper ball, remove the clip from the handle, lift the fubber ears of the flapper ball off of the plastic posts at the base of the bowl fill tube, and replace making sure that there is not to much slack in the new chain, just adjust the clip on the new chain where there is just enough so that the new ball seats.
Make sure you turn the water off to the toilet before you replace the flapper ball your valve in the tank will open to fill the tank and it will run until you get a new flapper in place.
You can het a new flapper for a few bucks at Lowes, Ace, even Wal-mart
Mar 13, 2011 | Caroma Home
What toilet seat hinge replaces Bemis elongated closed front toilet seat (plastic/not a bar/pair of hinges) and who sells? Can't believe Bemis does not support to proclaim hinges set in warm plastic...
The hinges and bumpers on plastic seats are not replaceable. The bumpers are molded in and the hinges are installed with special tools while the plastic is still warm.
Sorry but that's way Bemis does things and is way most good Plumbing shops will not buy or sell them.
They were not like that untill they started having their seats made in China however this may help you http://www.bing.com/shopping/search?q=bemis+toilet+seat+replacement+parts&FORM=HURE
http://www.bizrate.com/plumbing-supplies/oid1620858646.html
Mar 11, 2011 | Bemis 7MCLRDRCT NA Elongated Toilet Seat...
We bought a Kohler Cimarron complete solutions 2 pc. toilet about 2 months ago and now it doesn't want to flush properly.The toilet fills half way up with water instead of just wooshing down like it...
Before taking it out you need to go back to Lowe's and purchase a toilet auger....
With this you can crank it down through the trap of the toilet and remove the obstruction...there is something in there that a plunger will not remove...example...a pen or pencil... comb...these are commonly removed when I het the symptoms you are giving...
heatman101
Aug 13, 2010 | Kohler Cimarron Comfort Height elongated...
My flushometer toilet will not stop flushing. The
Try checking the water pressure. If it has dropped too low then the valve will never re-seat properly. Ideally over 90 psi.
Apr 02, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Pegasus HET toilet splashes water when it flushes
make sure the fill valve is not cracked,that's the long tower looking thing on the right side of the toilet when you stand in front of the unit. you can replace this part at homedepot. it is called a fluidmaster 400A.good luck.
Jul 16, 2009 | Home
Home Logo
105 people viewed this question
Top Foremost Home Experts
Donni Steen
Tom Chichester
Are you a Foremost Home Expert? Answer questions, earn points and help others
