Question about LG Vacuums
How to disassemble bagless vacuum cleaner LG Kompressor?
  • LG Master
  • 2,210 Answers
If the main factory website doesn't have parts lists, go to somewhere like Sears parts or other appliance spares sites which will give you an idea of how the bits fit and where the screws are. Be aware of the safety element of correct connections etc.
Posted on Nov 18, 2014
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
EwingElect
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
  • 33 Answers
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Posted on May 19, 2009
  • 16 Answers
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Posted on Nov 03, 2009
  • 731 Answers
SOURCE: how do I find a
Belt Part # MAS61843401
Can be bought from Sears $9.99
Under Head Base parts.. Ref # BBE1
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Vacuum-Parts/Model-LUV200R/3204/0645000?blt=05
Posted on Jan 06, 2011
Suction
If the motor comes on then either the shaft connection at the fan is loose or the belt to the beater bar is bad.
Jul 12, 2013 | LG Electronics Kompressor Pet Care Upright...
Vacuum wont **** and turns off after 2 minutes of vacuuming
you must av some of the blanket still stuck in there that's why it keeps stopping because it's overheating check for more blockages
Dec 28, 2012 | LG Electronics Kompressor Pet Care Upright...
Hose has no suction
I have found uprights absolutely choked with pet hair. Check the suction path
Sep 22, 2012 | LG Electronics Kompressor Pet Care Upright...
When operating smells like burnt rubber. Roller brush stopped turning.
Hi leanneaj...
Your problem is caused by hair,strings,etc getting around the beater bar at the ends of the roller where the bearings are and causes it to sease up.
The smell you smelled was rubber burning, the rubber belt that operates the roller brush has burned into...broken.
You will have to remove your roller brush and clean, and oil and then reinstall it with a new belt
Please take time to rate me
Sep 04, 2011 | LG LUV300B Bagless Upright Vacuum
I CAN'T FIND A SERVICE MANUAL FOR AN LGV300B VACUUM
Check this link and you will see a PDF download for owners manual for you to download.
http://www.lg.com/ca_en/support/product/support-product-profile.jsp?customerModelCode=LUV300B&matchedModelCode=2300001563&searchEngineModelCode=LUV300B&initialTab=documents&targetPage=support-product-profile
Mar 31, 2011 | LG LUV300B Bagless Upright Vacuum
Is there a manual for installing new drive belts on my LG Kompressor - we've had it for less than a month and the belt broke. I ordered 2 replacement belts and the new one doesn't work and the brush won't...
You've probably figured this out, but my luv200R had the same problem. The belt broke, I changed it and it still didn't spin the brushes. Turned out, the roller has bearings on either end and one of the bearings was bad and wasn't letting roller roll. So the pulley would spin against the belt and heat up and break it again. I took the bad roller to Sears where they had a new one sent to my house free of charge since it was less than a year old.
Mar 03, 2011 | LG LUV200R Bagless Upright Vacuum
Are there any stores that carry a belt for the LG Kompressor? such as Sears or home depot?
Absolutely, Crucial Vacuum has all the LG replacement parts you need. For the vacuum belt, here is the link: http://www.crucialvacuum.com/LG-Kompressor-Vacuum-MAS61842501-Belt-p/lg_vacuum_belt_5eph271.htm.
Jan 28, 2011 | LG Kompressor Upright Vertical Cyclone...
Need a belt for Kompressor vacuum. Micro-V=5EPH271
I NEED A LG LV200R BELT Kompressor vacuum. Micro-V=5EPH271
Jan 25, 2011 | Vacuums
Vacuums Logo
112 people viewed this question
Top LG Vacuums Experts
Think Crucial
Think Crucial
Ed Mac
Are you a LG Vacuum Expert? Answer questions, earn points and help others
