Question about EDENPURE Model USA1000 Quartz/Copper Heater
We changed the bulbs in our edenpure USA 1000 and now it only blows cool air. what happened?
Amcor a12000e not blowing out cold air
Halo
Inside of the unit you will find (see attatchment) a feeler bulb witch will be faulty. You might only find 1 feeler bulb witch will be highly rare most of them has two, one for heating and one for cooling.
Now what happens is on the evaporater where it will be located is if on heating the fan does not start until the bulb picks up that the evaporator is warm enough same goes for cooling, only defrence is that it starts the fan when the evaporator is cold enough.
Hope this was helpful.
Regards
Jun 25, 2016 | Amcor Heating & Cooling
I just changed heating elements in my edenpure usa 1000 and now it keeps tripping my power strip ?
Check to make sure that the elements are weird in the right place.
See if there is any loose screws or metal on metal.
The elements might be bad
If wired wrong it may not be making a proper circuit.
Check the pcb boards to see if it is touching metal on the bottom side of board.
If you put a screw in the wrong spot it may be grounding something out.
Check all wires for bare spots
Oct 18, 2015 | EDENPURE USA1000 Infrared Heater
Blows only warm air, not hot
Many of these heaters have four infrared heating bulbs inside, and they do burn out over time, and it doesn't put out as much heat. If you take off the outer case (usually 4 screws hold it on) you'll see the bulbs and will be able to determine which ones are not lit up and need replacement.
Oct 19, 2014 | EDENPURE USA 1000 Black Portable Heater -...
The fuse keeps blowing inside the edenpure heater
Generally speaking, fuses blow when too much current passes through them. Typically this happens when there is a short circuit some place. a connector or bare spot in a wire touching ground, a bad component on a circuit board, a bit of conductive debris on a circuit board all can cause shorts. If the fuse blows, it's doing its job to protect you from a problem you have yet to find.
Dec 01, 2013 | EDENPURE USA1000 Infrared Heater
Edenpure xl1000 parts
Replacement bulbs can be gotten from edenpure parts or check EBay for a supplier. Some will ship them no charge. To change them. Remove rear cover, then the cover on the rear of the heater box by 2 screws on the bottom and 1 at the top inside of a "U" Channel. Then lift the rear box cover up off the hanger hooks then back and out. The bulbs will be right in front of you in the 3 holes.
Jan 25, 2013 | EDENPURE USA 1000 Black Portable Heater -...
Need repair manual for eden pure heaters
The Edenpure Gen4 and US-1000 have a set of 3 - 500 watt bulbs that generate the heat. You'll likely need to buy a new set of bulbs every heating season ($60) or pay an Edenpure service center $100-140 to replace them for you. (Almost imossible to get SCI to cover the the bulbs under their so-called warranty)
Unfortunately, despite the hype printed on the box and Suarez Corporation Industries advertising, those bulbs last less than 500 hours of operation in those heaters. Suarez Manufacturing Industries/Pinnacle Systems have no engineering staff nor did they perform any durability testing on the heaters or any heater components.
Thus you, as the consumer, are stuck with continually the bulbs (in the US-1000 and Gen4 at least).
Apr 01, 2012 | Heating & Cooling
How do you change bulbs on the EdenPure Gen4 model
Video on YouTube: Heating Elements - USA1000 and GEN4
Mar 26, 2012 | Kitchen Appliances - Others
Whats the cooling capacity
1 ton of cooling equals 12,000 BTU
2 ton of cooling equals 24,000 BTU
3 ton of cooling equals 36,000 BTU
1000 sq ft home needs about 30,000 BTU of cooling..... if you live in Kansas USA.
This is basic cooling. Hope this helps.
Mar 26, 2011 | Heating & Cooling
How do you change bulbs on the EdenPure 1000-XL
On amazon you can find proper bulbs, click here and take a look: Amazon com edenpure 1000 bulbs. I hope this was helpful. Cheers
Oct 15, 2009 | Kitchen Appliances - Others
EDENPURE Model USA1000 Quartz/Copper Heater Logo
184 people viewed this question
Top EDENPURE Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an EDENPURE Heating and Cooling Expert? Answer questions, earn points and help others
