Question about Beverage Air Refrigeration BB94G-1-B Refrigerated Backbar Storage Cabinet
Defrost timer doesnt work on brand new beverage air BB94G-1-B. what can I do? thanx for your help
Condenser keep freezing so fridge not cooling properly
  • 3,382 Answers
Since it is new it has a warranty. Contact the people you purchased it from and expect it to be repaired under warranyy.
Posted on Nov 19, 2014
Why isnt Fridge cooling
There are numerous reasons for a refrigerator to discharge only cool air; weak compressor, low refrigerant, etc.
However, there are two very common reasons for refrigerators the age of yours to under cool. 1. Dirty condenser coils. Check the condenser and ensure that it is clean. This should improve performance. If that does not solve your problem then 2. The evaporator is freezing up. This can be caused by a faulty defrost timer, a failed defrost element, or a faulty defrost thermostat.
Aug 24, 2014 | Frigidaire Kennmore Water Filter 2 Pack
Fridge isnt cooling
However, there are two very common reasons for refrigerators the age of yours to under cool. 1. Dirty condenser coils. Check the condenser and ensure that it is clean. This should improve performance. If that does not solve your problem then 2. Evaporator is freezing up. This can be caused by a faulty defrost timer, a failed defrost element, or a faulty defrost thermostat.
The fridge part of my style Amercian whirlpool 6th sense fridge freezer is not keeping the food cool
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hoping this will help in solving the problem...
Jul 03, 2011 | Whirlpool Refrigerators
My C373 Fridge only should be frost free but it keeps Freezing up and then doesnt keep anything cold anymore
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Fisher and Paykel Refrigerators
I have a KitchenAid side by side Model # KSRS25CKWH01. iT RUNS BUT DOESN'T COOL OR FREEZE.
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly. Step 1 - Find the Problem
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly. * Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches). * Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section. * Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working. * Compressor - Make sure your compressor is working with on and off clicking noises.
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover. Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer. Step 4 - Volt Test
Take care in solving the problem.....
Nov 02, 2010 | KitchenAid Refrigerators
Both sides of the refriderator is not freezing or cooling
hello,
I hope this work fine...Take care.....
Oct 31, 2010 | LG LRSC-26922 Side by Side Refrigerator
Freezer is not freezing and refrigerator is not cold
Step 1 – Find the Problem
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
Step 3 – Find the Timer
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
Hope this helpout.......
Aug 14, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fan turns on then off refridge not cooling
Step 4 – Volt Test
Take care.....
Aug 10, 2010 | Marvel 6BAR-BD Beverage Cooler
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Beverage Air Refrigeration BB94G-1-B Refrigerated Backbar Storage Cabinet Logo
488 people viewed this question
Top Beverage Air Refrigeration Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Beverage Air Refrigeration Office Equipment and Supply Expert? Answer questions, earn points and help others
