Question about RCA Televison & Video
How do i fix my rca 52 d52w20 chassis# atc221(i do not know if it is a rear projection or if it is just hdtv) it will give me sound but no picture?
    Master:
  • 742 Answers
Simple web search shows it is a crt rear projection tv. Your probably having a problem with the high voltage fly backs. You will more than likely need to have it serviced by a professional for proper diagnosis. Lots of high voltage stuff in there and you go poking around your likely to get one heck of a shock.
Posted on Nov 18, 2014
D52W20 chassis ATC221 picture is fuzzy,blurred,unreadable.I do have a"convergence" option on the menu.have not done anything to the fuse fl231 yet.Will it help if replaced?The convergence does...
Yes - that may help if its done correctly...Sites like www.TvRepairKits.com have the parts and also parts with instructions to do it right the first time.
Aug 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Our 52 inch RCA tv Model #D52W20 will not come on when we power it on. If we keep hitting the on button it will eventually come on. When it first started it would come on in about 10 min now it takes...
Replace the CP150, CP120 and CP114 Capacitors. You can get the RCA repair kit called the ATC221 CP150, CP114 and CP120 repair kit from www.tvrepairworld.com which contains the caps for the ATC221 and ITC222 versions of your model along with the CD with repair instructions.
Apr 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 52"
Yes the ATC221 uses the 259296 flyback. If audio works and the on screen menu also comes up but no video its most likely a vertical deflection issue. I would check the vertical IC for signs of bad solder.
Mar 29, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
After 10 minutes power shouts off
small signal board is the most likliest cause. That a common problem with the ATC221 and ITC222 that model used both different chassis designs. www.tvrepairworld.com has replacement boards available.
Feb 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 ATC221 TV Schematics/Service Manual
go to www.tvrepairworld.com they can assist you and they have all the components for the RCA ATC and ITC series televisions and very knowledgable staff for RCA problems based on symptoms.
Apr 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" D52W20 ATC221 TV Problem
The FBT is dead.The buzzing sound mean there no high voltage is come to the CRT(tv tube).No burning,marks on the FBT doesn't mean it not dead.I change parts all the time with out burn marks on them.Trust me i replaced dozen of the FBT before.It make buzzing noise it dead.
Mar 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
CONVERGENCE WILL NOT ADJUST ON SIDES
First you need to read the supply voltages to the STK's. Black things, size of 2 match books on a big heatsink. Sounds like your supply voltage is low, could be a bad STICK STK. usyually stk 130-20 or 150, etc..
Mar 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Don't understand
Can you look on the rear of your set and give me the chassis number and I can explain as that model used three different chassis designs one was ITC222, then ATC221 and ATC321 it should be marked on the rear tag.
Jul 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Picture wont come on
Whats the chassis number of your set. Have to have the chassis number to diagnose RCA. Should be on a tag on the rear of the set.
Feb 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
