Question about Philips Magnavox 27MS343S 27" TV
Television model tp2784c101 what is the remote control menu/set up to keep channel so it doesn't automatically switch to different channel after 30 seconds; or how can I set it up to turn onto AV1 an
Reviewing remote control commands to find setting to turn tv on to channel AV1 and cancel the setting that makes the channel change to 3 or revert to another channel
    Top Expert:
  • Philips Master
  • 75,452 Answers
If the TV do not respond to remote control; to change channels, there are many possibilities. Check the infrared emission of the remote control first. Check it with fresh batteries. If the infrared sensor inside the TV is faulty, this kind of fault can happen. In other words, your TV need a through check up, which a normal user can't do with ease. Contact any service technician; or the authorized service centre. Electro help
Posted on Nov 18, 2014
dmathwizard
  • 113 Answers
SOURCE: child lock will not allow my tv to turn on
Get a universal remote to do the above.
Posted on Mar 05, 2008
SOURCE: Philips tv turns on by itself and is stuck in demo mode
Change the eeprom
Posted on Mar 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
techjuli
  • 157 Answers
SOURCE: TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Posted on Nov 30, 2008
  • 188 Answers
SOURCE: philips 21rf vardan tv
Check option code's.
Posted on Jul 29, 2009
Lost all programs need to retune How
  1. Scan the channels
    1. Press the Menu button on your remote control.
    2. Select Channel and press OK on your remote control. For Aerial you must choose the Cable option.
    3. Go to Auto tuning and press OK twice on your remote control.
      - Set the Automatic tuning screen to Cable (vertical) and Digital (horizontal). - Then press OK on your remote control.
    4. Enter the following values:- Search mode: Quick- Network: Manual- Network ID: the code for your region (22 for Flanders and 12 for Brussels)
    5. Press OK on your remote control.
    6. For Frequency enter the value 322000 and press OK on your remote control.
    7. For Modulation enter the value 256QAM and for Symbol rate enter the value 6875.
      Then select Search (or Next, this differs by type of TV) and press OK on your remote control.
    8. Your TV now scans the channels.
Jun 02, 2015 | Samsung Televison & Video
AUTOMATICALLY CHANNEL / VOLUME AND MODE CHANGING
please check touch key board i think it is defect
thanks lal electronics
Jul 15, 2013 | Insignia 32" 720p Flat-Panel LCD HDTV
How do I turn off closed caption on Model TP2784C101?
If the remote control have a "CC" button on it, press it once to cose the Closed Caption option. If the remote do not have a 'CC" button, enter TVs menu option, surf through, come towards closed caption adjus window, and make clsed caption function to OFF, if it is ON.
May 21, 2012 | Philips TP2784C TV
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
I accidently locked my TV. I have no idea what the code is. When I switch on the TV there is a blue screen with lock written on it. The remote control is CHUNGHOP RM-441e Universal PLZ do help. The Whole...
Hello
You can unlock the FPA lock of your RCA TV. But, you must ahve its original remote control to perform the proceedings. if you haven't it original remote cntrol with you now, just try to buy a new one, of just borrow it from any of your friends or relatives who owns the same model Tv.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
One amoung the above process will surely unlock your RCA TV. OK.
Sep 20, 2011 | RCA TruFlat 27F520T 27" TV
I bought a Toshiba TV with remote CT90326 from a friend who had a different service (satellite) and I have cable and the remote works to turn on the TV , punch in specific channels, and to change volume,...
Any television remote will give full access to the television functions. The remote must be specific to that television. Google
make model replacement remote
There are original ones on ebay, plus companies that sell remotes that are an exact copy. The CT90326 may be for another Toshiba model, or of course it may be faulty.
Then we have the remote on the cable or satellite unit. That gives full command of the unit functions, but BASIC control of the television, normally On, Off, Channel Up and down to allow access to DVD or similar and Volume Up and Down. Everything else is done from the TV Remote.
To get the cable remote to make that happen, you Google
Toshiba Remote Codes
and run through them all until a selected code allows you to switch the television on and off.
Sep 25, 2017 | Toshiba Televison & Video
Hi, i have 14 "
As I see it, your problem has something to do with your remote. I bet you have pressed the "auto search" button of your remote that's why your TV keeps on searching channels automatically from channel 76 down. Here's what you've got to do:
1. Get your remote control
2. Turn on your TV.
3. Press the "auto search" button to stop your TV from automatically searching channels.
4. In case it works, I'd advise you to look for channels manually using the number buttons or the "previous" or "next" buttons.
5. If it doesn't work still, contact your technician or your service provider about it. They are of great help for you!
I hope it helps. Thanks a lot.
Jul 23, 2011 | Televison & Video
Instructions to tune Philips tv 54cm colour TV. Search & store channelss
Hello
You haven't mentioned about the model number of your Philips TV. Different models have different type of tuning procedures. Any way I hereby send a procedure to set it autotuned. If it Doesn't work, please inform me through Fixya, stating your TVs model number also. ok
Press "Menu" on the remote control handset, and select the installation language.
Select a language and confirm it by pressing "OK" button on the remote control.
Press ' button to return to 'Instalation' menu.
Press "Menu" on the remote control handset and select Installtion > Preferences > Location.
Select 'Home" and press "ok" to confirm.
Press ' to come to the Installation menu.
TO TUNE CHANNELS AUTOMATICLY AND TO STORE
Press "Menu" on the remote control, "Select Installation" '>' Channels '>' Autoprogram '>' Start now.
Press "OK" and allow the start installation automatically.
If you run autoprogram when you have locked channels, a messege appears asking to enter your PIN code in order to complete instllation.
Try this, if doesn't work inform me with TVs model number. OK.
Nov 04, 2010 | Philips Televison & Video
My rca tv 20f424t doesn.'t show thw correct
That is the Digital range of channels, since it is digital you will not need a converter box for this model. Their is also an Analog range of channels which is the primary setting, You will need the factory remote to switch from Analog to Digital... Without that remote you might have a problem their isnt a way to switch within the menu settings, good luck!!!
May 11, 2009 | RCA Televison & Video
Unable to automatically scan for channels. menu button on remote does not work om my 1992 jc penney tv. No buttons on outside of tv except for the basic channel up/down and volume control. Recently...
To make it easy for you - you should have original remote.
Then through the menu look for channel set up then make sure you select cable or antenna then you do autosearch(sometimes called autoprogram).Unless the tuner is defective,you should be able to program withe the original remote.
Jul 19, 2008 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
