Question about Nokia Lumia 928 Verizon Wireless
Is Cortana available on the Nokia Lumia 928 (Verizon)? I can't find her - is there a way to get her?
My langauage, region, and speech are on US English, she is not in my settings or apps, and will not pop up when I press the search key.
    Sergeant:
  • 236 Answers
If your phone shipped with Windows Phone 8 you will have to wait until your carrier releases 8.1 for Cortana. Once you are on 8.1, it then depends on which country you are in. With the 8.1 Cortana is available only in US until the "8.1 Update" comes along.
Posted on Dec 08, 2014
How do I find or where do I find APN?
There is no need of APN....jus set default configuration
Jan 17, 2016 | Nokia Lumia 635 &Cortana& 8GB Unlocked GSM...
After selecting allow speech over locked screen, my nokia lumia 530 is locked please how do I reverse that?
Hard Reset NOKIA Lumia 530 - HardReset.info
www.hardreset.info/devices/nokia/nokia-lumia-530/
Hard Reset NOKIA Lumia 530; In the next step go to Windows Phone Settings. Master Reset NOKIA Lumia 530; Afterwards select About. Wipe data NOKIA ...
nokia lumia - Phone is locked and says I need to wait for ...
windowsphone.stackexchange.com/.../phone-is-locked-and-says-i-need-t...
Sep 9, 2013 - I locked myself out of my phone by entering the wrong password too many times. However, instead of the usual "Try again in 1 minute" ...
How to unlock Nokia Lumia 530 - sim-unlock.net
sim-unlock.net > Unlock Nokia
Your Nokia Lumia 530 is locked to only one network ? You can unlock ... Check how fast You can unlock Nokia Lumia 530 by using our site. We give You full ...
Nokia Lumia 530 - How to unlock security code by hard ...
? 13:44
https://www.youtube.com/watch?v=q8OjYvinAxo
Nov 11, 2014 - Uploaded by phone reset
look i forget my password of my nokia account so i reset mylumia 635 it works? or how i can erase mi nokia ...
Jan 05, 2016 | Nokia Cell Phones
Why don't I receive text messages when the phone is powered down.
the phone must be on to receive texts
email will be downloaded when you turn on the phone
Sep 17, 2015 | Nokia Verizon Wireless Lumia 928 Windows...
Why am I unable to receive text messages when phone is powered down?
Because it is OFF. Power must be on to use any of its functions - like the way a TV set must be on to watch it.
Sep 17, 2015 | Nokia Lumia 928 Verizon Wireless
Can you help me unlock my phone I forgot my passcode lock
While the device is off hold the home button and the volume up button at the same time as the power button until a special menu appears you can then reset the phone to factory settings which will which may erase all your personal content but the phone will be as though you had just purchased it
Sep 06, 2015 | Nokia Verizon Wireless Lumia 928 Windows...
I forgot the password for my nokia lumia 928 how do i unlock it
Note An alternate reset method is available if the device can be powered on and is responsive.
Ensure that the device is powered off.
Press and hold the Volume Down button (located on the right-edge of the device; above the power button) until instructed to release in step 4.
Press and hold the Power button until the device vibrates (approximately 2 seconds) then release.
Note Alternatively, connect the device to an approved USB charger while continuing to hold the volume down button.
When the restore screen appears (exclamation mark), release the Volume Down button.
From the restore screen, press then release the following buttons to initiate the reset process:
Volume Up
Volume Down
Power
Volume Down
Note Allow several minutes for the process to complete (rotating gears appear on the display to indicate that the reset is in process).
Note To setup the device after the reset has completed, refer to Initial Activation and Setup.
How do I transfer pictures from Nokia Lumia 928 to laptop
You can transfer photos from your nokia lumia 928 to laptop wirelessly or wired. Wired transfer is the easiest way when your unit comes with the data cable and the software. Now, if the software is not inclusive you can set your CP's connection settings "Connected as USB memory" however you may have difficulties in viewing since the connection layer platform is not capable of viewing the pictures or images but you can view later after you copied it on your laptop. Now, if your unit doesn't come with data cable and software you can use the BLUETOOTH connection by simply turning or enabling both Bluetooth device on your laptop and cp which can be found in settings usually, once enabled and set visible you will noticed both devices sees each other with their name if not try to search manually by pressing search and chose paired bluetooth device with confirmed access code or id. Right then, when connection is successful you can start copying pics or images to your laptop. (Make sure you know the directory your pics are being copied, it is usually saved in bluetooth download images directory or other directory, pls manage to locate). Thanks hope this helps... Goodluck.
Oct 07, 2014 | Nokia Lumia 900 Smartphone Black Unlocked
My NOKIA smartphone won't turn on
A pretty quick fix for many Nokia Windows Phone issues is a soft reset. It does not erase data or lose installed apps. Holding down the volume down button and power on button for about 10 seconds will power cycle the phone. Similar to pulling the battery. If it doesn't fix this issue it is still good to know how to power cycle a Nokia Windows. Phone. This worked on my 820, 928 and Ikon (929) phones.
Oct 06, 2014 | Nokia Lumia 928 Black Smartphone - Verizon...
I have reseted my phone more than 4 yimes and it is still frozen. What should I do
Reboot and reset if it don't work take it to the shop had the same prob with my blackberry
Sep 30, 2013 | Nokia Verizon Wireless Lumia 928 Windows...
Nokia Lumia 928 Verizon Wireless Logo
119 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
