Black screen on 39" teknika tv but has sound
Black screen but had sound
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Posted on Nov 18, 2014
How do i fix a vizio 42" tv with a black screen, no sound
THE MAIN BOARD AV BOARD HAS WENT OUT JUT HAPPENED TO ME TODAY
Feb 28, 2013 | Vizio Razor M421nv 42" 1080p Hd Led Lcd...
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
My tv has sound but has a black screen
You'll need to take it to a shop to find out the problem
(retired Electronic's tech)
Sep 11, 2012 | Televison & Video
My Element 32 inch tv has black screened.
hope I dont sound too crude, but have you checked the contrast and brightness controlls ?? they may be labled as 'picture options' or some other odd label...
does this tv have a LED, LCD or the older CTR display ?? If it is LED or LCD, then the light source that illuminates the screen are not working.. this light source could be damaged..
Sep 09, 2012 | Televison & Video
Why do i have a green screen after turning the screen adjustment screw?
Those screws are meant for a professional to fine tune the colors. It sounds like you moved the screw too far.
A flashing black screen could have been an issue with the control board. It sounds like it's either time for a new TV or to send it to a TV Repair tech. A new TV might be cheaper.
Jul 10, 2012 | Televison & Video
Trying to get a code for a Technika TV - the tesco brand to use a jumbo remote control
hi,
Codes for Teknika tvs are,
000, 001, 004, 005, 008, 009, 013, 042, 051, 053, 058, 105, 109, 170, 174
OK
Aug 16, 2011 | Innovage Jumbo Remote Control
When I turn our tv on the power light comes on but the screen is still black and there is no sound.
Black Screen - Sometimes, the TV may display a black screen, now you need to check the cables whether they are properly plugged or not. Reconnecting all the cables can also work for this problem. Also, if the screen has a screen saver, check how it's set up. And, if nothing works for this issue, then there is a possibility that the lamp, rear projection, or the LCD panel may have been damaged. Now, you need to check your warranty card of your television and se your set comes under the manufacturer's warranty period. Call the customer service for technical problem and get replaced if a part demands it.
consigning no sound on your TV
You might need to do some troubleshooting tips first before calling arepair man to replace the sound IC inside the TV.
Check the volume setting. It might sound simple, but it's the best place to start. Make sure the television sound is not muted or turned all the way down using the remote or buttons on the front of the television. If the batteries are dead in the remote and the TV is muted or turned down, it might seem like the sound is broken.
Examine cables connected to the TV. Sometimes a loose connection can cause a loss of sound. Ensure all cables are tightly connected to the television and correctly inserted. Some peripherals are connected using a three-plug system and are usually labeled red, white (sometimes black) and yellow. Both the red and white leads are sound cables. Try removing all the cables (except the power) from the back of the television and turning it to TV mode, then listen for static or other sound.
Plug in headphones to the television with all cables re-attached. See if you can hear sound through the headphones. If you can, it may indicate that the TV's internal speakers are not working. If you can't hear anything through the headphones, it may be indicative of a larger problem.
Call a repairman. If at this point everything has failed to produce a sound, it's time to call in the professionals. A qualified technician should be able to fix the problem either at your home or in a workshop.
May 25, 2011 | Televison & Video
47" plasma 1080p ... screen went black , sound
Plasma TV's have a shelf life. By that I mean the screen is only good for so many hours depending on the model. Most likely, you have burnt out the screen and the set will need to be replaced. The good news is, plasma TV's used to be better than LCD but that is no longer the case. You can get a very high quality LCD TV for a very low price now. Also they use a fraction of the power and don't generate all of the heat of a plasma.I'm sure this is not what you wanted to hear but the reality is that ALL plasma TV's do this eventually, and it is something that most salesmen back in the day didn't bother to tell customers. If you have an extended warranty, you may be able to get it replaced.
May 05, 2011 | H&B HP5500V Plasma TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
