Question about Vizio E470VL 47 in. HD-Ready LCD TV
Vizio Model E470VL, HDMI ports are not functioning properly.
All HDMI ports work when an XBox360 is connected, however do not work when other components are connected. Have tried PS3, Xbox One, cable box and Blu-ray player using same cord that works with Xbox 360. Any ideas?
    Scholar:
  • 65 Answers
On some TV's the Analog board is where the other cables plug into. I know on a Sanyo I am working it looks like the analog and main digital board are all the same. but they are just hooked together. I bought an analog board for less that $30 from Shop Jimmy.com. The prices might vary according to the make and model of TV. need to be careful and remove the back of the TV . and get the part # directly off the board. BE SURE TO UNPLUG from the wall outlet first. Nearly all the boards carry a charge even when unplugged so be careful.
Posted on Nov 18, 2014
2 Suggested Answers
  • 114 Answers
SOURCE: Our 42" Vizio will not display/play sounds when
Hello
One board takes in the HDMI as well as the other signals. Sometimes part of the board breaks and that is what sounds like has happend in your case. This is a fairly common problem and most people tend to just live with it. Others sell thier tv and a few find the number of thier board to see if one is available on ebay or shopjimmy. If you are comfortable with electronics the board is not hard to replace.
Im sorry your HDMI broke....
I hope this helps
Posted on Nov 28, 2010
Vizio E470VLE HDMI inputs not working
its the antanna don't go on your roof you probs bumped it
Aug 31, 2016 | Vizio E470VL 47 in. HD-Ready LCD TV
Vizio Model M470SV HDMI port nor working (won't recognize dvd player,Xbox,play station etc)
This unit has four HDMI ports. Input is not automatically set to the port that your devices are connected to. Take a look at the markings that correspond to the port that your peripherals are connected to, then use the Remote Control to change the respective HDMI port.
With your external device connected and turned on, press the HDMI button on the Remote Control several times in succession until the proper HDMI port is displayed. Output from your device should now be displayed on the screen.
Nov 27, 2014 | Vizio Televison & Video
Vizio E470VL with no sound after main board replacement
No, your video and audio processing should take place on the same main board.
Feb 12, 2013 | Vizio E470VL 47 in. HD-Ready LCD TV
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
I have a wd-62525 dlp i have pic and sound through ant. and hdmi but on component and video inputs i only get sound no pic
Hello
It seems to be some fault with its HDMI cable you connect to this device from the source. As you get sound by HDMI, and no picture at all, this indicates the fault with cable itself. There is a cution notice says that " To assure continued FCC compliance, the user must use a shielded video interface cable
with bonded ferrite cores at both ends, when using the PC or HDMI input."
Cheang the cable and check.
Oct 10, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Vizio E470VL 47 in. HD-Ready LCD TV Logo
207 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
