Question about Zodiac Jandy Ae-Ti Heat Pump 74K Btu
My jandy heat fan motor will not start motor is new
I have just installed a new r3000701 1/2 hp fan motor heater will start but fan will not unit goes to defrost mode
  • 2,210 Answers
Electric motors usually need a Run/Start Capacitor. Did you replace that as well? Did you have an electrician test that and the motor. A capacitor is a few bucks compared to a motor.
Posted on Nov 18, 2014
When he unit goes to start the fan motor doesn't start moving
if voltage to fan motor bad start up capacitor replace motor
Nov 10, 2013 | Jandy Air Energy Heat Pump - 100,000 Btus
I bought a fan motor for my hp 2100, when i went to swap it i found the new fan had 1 less hot wire than the old 1. when i installed it, it does not work. could i have bought a 110 motor when i need a 220?
old motor has data needed for replacement. hp, sf ,rotation ,rpm, volts and amps.plus capacitor size required. the extra wire can be for a capacitor conection usaly brown in color and if you look at the label it will tell you how to eliminate the need for this wire.
Aug 21, 2013 | Hayward Heat - Pro 2100 Heat Pump Pool...
Installed New Motor on pump. Getting whining noise and and lost pressure in basket.
when you replaced motor is wiring correct if 120 volt you have to change wiring or it will whine and no pressure
Jun 14, 2012 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Air flow failure indicated on heater
Mine does the same. Sounds like you checked the air pressure switch, but the high temp switch and bad airflow can also cause this problem. Check the two white wires that lead to the heat sensor vent drain tube exits. Make sure the spade connectors aren't shorted. Try testing the temp sensor like you did the pressure switch to make sure the circuit is properly closing when in use (or use a temporary jumper to bypass as a test.) Check the bottom of the pan for any dust or crud that could block the airflow below or around the burners and last of my options- increase clearance around the unit to aid air flow.
Jun 01, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
5 year old Laars 25,000 LX won't ignite.
The low pressure indicator is for the gas pressure not the water pressure. The heater won't ignite because it's not getting gas to the igniter. Check gas supply, if okay, check gas connections, valves, etc.
The 1 HP motor should be fine on the jacuzzi.
May 26, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Zodiac Jandy Ae-Ti Heat Pump 74K Btu Logo
112 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
