Question about RTO Freespirit 817 Treadmill Walking Belt
I changed the speed sensor and it still shows L5 error what else could it be
My treadmill not running after 7 seconds diplay shows L5
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It is common to see this error as and L5 error, but it is actually an LS error. The following information will define this error and give you the possible solutions to fix this issue.
LS Error with No Belt Movement on Landice Series Treadmills
LS Error on Landice L-Series Treadmills with No Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
Corrective Action A) Enter Open Loop Speed mode and set treadmill speed to confirm proper line voltage to pwm board and that the green BELTSW light is lit on the relay board. Replace upper display board or relay board if necessary.
B) Inspect speed control wiring and correct wiring if necessary:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
C) Inspect motor control wiring, checking wires from motor to A+ and A-. Correct wiring if necessary.
D) Inspect motor brushes verifying brushes slide freely, are at least 3/8" long, are curved and have no burns or cracks. Also check the brush springs and verify that the brush copper wire is not burned or broken. Replace both motor brushes if necessary.
E) Inspect motor turns and is not seized up or has a broken shaft. Replace motor if necessary. Also verify at least 90VDC present from the black (A+) wire and white (A-) wire from the pwm board to the drive motor. If voltage is present, replace pwm/relay combo board. If no voltage present, replace drive motor.
Details about LS Error on Landice Series Treadmills with Belt Movement
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
Correct speed control wiring if necessary.
Oct 13, 2015 | Exercise & Fitness
What is l5 error
This error can also occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:
If you find yourself needing any further assistance please do not hesitate to call our technical support team at 888-713-2880 or check out our technical support center at http://www.sportsmith.net/supportsearch.aspx we would be more than happy to help!
Aug 03, 2015 | Exercise & Fitness
Speed sensor L5
follow this steps and fix it. God bless you
SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH belt movement
This is usually an indication of a speed control malfunction. The upper board is not recognizing a signal pickup from the speed sensor. This could be due to the speed sensor being misaligned, improper connection, or bad speed sensor. Refer to the flowchart on page
"SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH NO belt movement
The speed sensor is not recognizing any motor movement. This displays the error message to the upper board.
NOTE: USE THIS FOR DIAGNOSING THE PWM/RELAY COMBO BOARD
Oct 21, 2013 | Landice Exercise & Fitness
I have York intensity treadmill and its not working, the L 5 keeps showing on screen.
Test the input voltage 2)test the relais 3)see sensor speed wiring 4) test terminal motor.
God bless you
Oct 09, 2013 | York Exercise & Fitness
My landice 8700 programable is showing an L5 error and does not run how do i replace the switch that is bad with this treamill it only has an up and down button for more or less speed
Mar 14, 2011 | Exercise & Fitness
My bowflex treadclimber starts for abut 3sec then err L5 shows on the screen PLEASE HELP!
The machine needs to be re-calibrated if its an L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
Jan 22, 2011 | Bowflex Treadclimber
New free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
Feb 08, 2010 | Precor C954i Commercial Treadmill
My Bowflex Treadclimber keeps coming up with an Error L5. This error message shows up 5 seconds after turning the machine on. My husband looked it up yesterday and said that the machine needs to be...
L5 due to the screen is actually LS (lost signal) the first place to check is the gap of the speed sensor. under left treadle 2 black wires. Removing the rear covers will allow you to see the lwr cntrl board and move the belt by hand. The gren led light should flash once per revolution of the drive pulley. If not then it is the speed sensor. Adjust sensor to pully about thickness of a credit card. then calibrate unit.
LS is also tripped by any broken wires or bad connections. Start at sensor and board first.
Jul 21, 2009 | Bowflex TC3000 Treadclimber
I have a Landice L8 and the error code L5???
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
RTO Freespirit 817 Treadmill Walking Belt Logo
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
