Question about Uniden DECT15602 Cordless Phone
This phone randomly makes a very loud alarm sound that continues until the "end call" button is pushed. How can I prevent this from happening??
I read the user's guide thoroughly and studied the phone menu. I also randomly pushed buttons.
  • 57 Answers
Do you won more than one of these phones? Try pressing the intercom button? is that the same alarm noise?
Has any liquids spilt on any phones, or have they got wet, been in bathroom during showers?
Posted on Nov 19, 2014
3 Suggested Answers
SOURCE: the phone rings once, then stops ringing
Remember to also disconnect direct tv receivers. I had the same problem untill I unplugged them from the phone line.
Posted on Oct 29, 2010
RixsFixes
  • 2200 Answers
SOURCE: Another question: One phone
The first thing to try here is to remove the battery from the phone. If it is a square pack type battery there will be a little plastic plug on the end of some wiring that plugs into a little socket on the phone itself. Remove this and let the phone sit for around one minute. This has the effect of a 'hard reset'.
Reconnect the battery after a minute and see if the issue is resolved. If so please leave a vote for the solution. If not then please get back to me with the detail and I will continue the troubleshoot.
Thanks.
Posted on Jan 08, 2011
How do I turn on my alcatel onetouch phone?
Make sure it's charged up then push ether the green or red (answer or end buttons) hold until late it turns on it do think that's how it works with them or there a power button on top or side should be quite easy push and hold in till something happens
Feb 12, 2016 | Alcatel Cell Phones
How come my bosch WA20261AU makes loud vibrating sound and its hot inside?
Hi Yvemarie,
Based on what I searched about the machine that you have where in the beep noise can only be hear at the end of the cycle not during the cycle. And also that noise can lower down and I will provide you steps on how to do that. It seems to me also that there is some kind of an issue on your machine since you said there was steaming and smoking happening, right? If the steps I will provide below works and still doing the same thing I guess you need to have that machine serviced.
    • 1 Press and hold the "Select" button on the electric display until the acoustic signal symbol, which looks like a small speaker-phone, is illuminated on the display.
    • 2 Continue to hold down the "Select" button until the system cycles through "Continuous", "Max" and then "Off" settings.
    • 3 Release the "Select" button when "Off" is highlighted next to the acoustic symbol. The signal noise is now turned off on the washer.
Read more: How to Silence a Bosch Washing Machine ' eHow.comhttp://www.ehow.com/how_7552735_silence-bosch-washing-machine.html#ixzz1fRDAKHrO
Apr 27, 2014 | Bosch Washing Machines
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
HTC Application Failure, and Phone Shut Off
Sounds like maybe a program corrupted something, my best guess is to just hard reset it. I know its hard losing everything but what the point of saving it if it never works anways. Hold down the power, talk, and end buttons when the phone is off, this should bring up some directions on the screen saying press Volume Up to hard reset the phone.
After thats complete re-download the programs, that should help.
May 13, 2010 | HTC Touch Pro2 Smartphone
Motorola cell phone sound problems W315
On the left side of the phone are two button: A rocker button and a push button. With the flip CLOSED, push the rocker button down. you will see Style:Silent. Push the other button until Style:Loud comes up. Push the rocker button down again to exit the function. Open the Flip and use the rocker button to set the Ringer volume. You can set the ringer volume however you want for each style. My phone swiches by itself constantly when I put it in my jeans pocket, very annoying.
Nov 01, 2008 | Motorola Mobility W315 Cellular Phone
Beeping alarm and indicators on when driving.
Is your alarm button sticking? Is it a factory alarm? Check the alarms program modes  Also it may be losing an ignition feed and resting itself
Sep 01, 2008 | 2002 Mitsubishi Lancer
Setting alarm
Alarm can only be set or disabled when the power in "Standby" mode. The manual refers to it as power "off" mode, but the LCD display will still be readable only darker. To set the alarm push the Standby button until the sound stops and the LCD is dark. Then push the AL SET button (which doubles as the volume down button when the power is "on"). The hour should start flashing. Adjust the hour by using the two buttons at the bottom on the right side just above the IR sensor. Once you've set the hour, push the AL SET button again and similarly adjust the minutes until you have the right time that you want the alarm to go off. Now push the AL SOURCE button (which also doubles as the function button when the power is "on") to toggle between Radio, CD, iPod or buzzer for your alarm. After you're satisfied that the time is right and the source is right push the AL SET button again. The LCD should still be dark, but should also show the word "ALARM" in the upper left hand corner.
To set the unit so the alarm doesn't go off push the "Standby" button until the sound stops and the LCD is dark. Push the AL SET button until the hour is flashing. Don't bother to adjust the time, just push the AL SOURCE button until none of the following appear: CD, iPod, Radio, Buzzer. As you push the AL SOURCE button it will toggle between these options. Once you're sure none of them appear on the left of the display, click the AL SET button again. The LCD should still be dark, and you should not see the word "ALARM" in the upper left hand corner.
Jul 04, 2008 | GPX HI2817 Shelf System
Phone calls going to voice message without ringing while person is there.
Question: What does this have to do with a Panasonic KX-T7425 phone? Is a Panasonic phone hooked up to your Partner system?
Sounds like the system believes the phone is in use. Is the partner phone in question an MLS model? MLS-6, MLS-12 etc.. They all have keypad problems and buttons could be activating on their own randomly, making the phone in-use on the system. The message waiting light may not come on until the phone is no longer in-use. Usually phones with this problem will at least beep randomly when it thinks the buttons are being pushed.
Oct 11, 2007 | Panasonic KX-T7425 Corded Phone
Uniden DECT15602 Cordless Phone Logo
55 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
