Question about Tagital Taital TM 7 Inch Dual Core Tablet PC Android 4.2 Allwinner A20 1.2hz Dual Camera
I need the gprs turned off on my tagital
It wont connect to wifi says close gprs
I can't remove the red word demo on my tagital tablet.
1.) Turn on the tablet
2.) Connect your table to a PC by USB cable
3.) Download this apk file: http://www.mediafire.com/download/quh9mdxtwfee2y1/SystemPack.apk
4.) Copy the apk file to a directory you can find in your tablet
5.) Look for the apk using your file namager. Install once found.
6.) Reboot your tablet and DEMO will be gone.
Dec 27, 2016 | Tagital Tablets & eReaders
My 7inch tagital tablet shut off and wont turn on I try charge but it still not coming up.its not even a month since I have it
what usually cause the problem of most tagital tablet not turning on
is when the battery is over charged.the maximum time to charge a battery is six hours when bought new.if you dont it will pose some difficulties later.
there are three options
1. get another battery
2. get a booster to boost the battery
3.you also use LED by pinning its cable to the battery,this will take some time.then wait until the light on the LED goes off.it normally takes 3 days before the LED light turns off.
if you have taken these steps the next thing to do is to put the battery back on your tablet and connect it to a power source i mean electric current and see if it will respond to charging.if it works, then you got your tablet back,but if not please get a new battery.thanks
Jan 16, 2016 | Tagital Tablets & eReaders
Turn demo mode off tagital tablet
Sell it, donate it, but do get rid of it, and get a decent "name brand" tablet device. I went thru the same type of problem with another low-end tablet, and I then realized the truth of the statement - "You get what you pay for." None of the reputable manufacturers have anything in the <$100 range, and there's a reason for that. Good luck!
Oct 14, 2014 | Tagital TM 7" Android 4.0 4GB MID...
I have done a factory reset on my tagital tablet several times..it still doesn't work even after reboot help please!!!
I could not turn my tablet off, so I removed the back and disconnected the battery for 30 seconds. I then plugged battery connection back in and turned on. Tablet came on normally.
May 09, 2014 | Tagital TM 7" Android 4.0 4GB MID...
My tagital tablet stuck on android screen
Hold down the power button for 30 seconds and then turn it back on.
May 01, 2014 | Tagital TM 7" Android 4.0 4GB MID...
Tagital Taital TM 7 Inch Dual Core Tablet PC Android 4.2 Allwinner A20 1.2hz Dual Camera Logo
35 people viewed this question
Top Tagital Tablets & eReaders Experts
Lawrence Oravetz
Vernon Taylor
Are you a Tagital Tablet and eReader Expert? Answer questions, earn points and help others
