How do I fix a flickering light lamp?
I replace the lamp, still flickering lamp replace.
  • Office Equip... Master
  • 9,742 Answers
The ballast board controls the lamp. Replace it and you should get full brightness.
Posted on Nov 19, 2014
Is there a service bulletin for a Pontiac G5 for electrical issues?
their are 7 recalls on the 07 none are for an electrical problem with lighting system
http://www.pontiacproblems.com/recalls/G5/2007 and the following tsb from march 2010 is for flickering lights
  • TSB #PIC-5073B NHTSA ID #10034409
    • Date Announced: MARCH 01 2010
    • Additional Info: How to Fix
    Summary: CHEVROLET/PONTIAC: VARIOUS ELECTRICAL CONCERNS. SIR LIGHT, IP LIGHTS FLICKER/INOPERATIVE, PARKING LAMPS FLICKER/INOPERATIVE, TAIL LAMP DIM/INOPERATIVE, TRUNK OPEN LIGHT, RADIO INOPERATIVE DOOR LOCK INOPERATIVE, NO START, NO CRANK. POSSIB
    More Information »
ELECTRICAL SYSTEM:WIRING
  • TSB #PI-0817 NHTSA ID #10047261
    • Date Announced: SEPTEMBER 01 2012
    Summary: CHEVROLET/PONTIAC/SATURN: ENGINE FAILS TO START AFTER ENGINE CRANKS DUE TO FUEL PUMP WIRE HARNESS CONNECTOR NEEDS REPLACING, WITHOUT REPLACING FUEL PUMP COVER ASSEMBLY (FUEL PUMP FLANGE). MODEL 2007-2010 COBALT, G5, ION. *PE
    More Information »
ELECTRICAL SYSTEM:FUSES AND CIRCUIT BREAKERS
  • TSB #PIC-4578 NHTSA ID #10022806
    • Date Announced: JUNE 01 2011
    Summary: EPS/STR WHEEL CONTROL FUSE (#19) OPEN. *KB UPDATED 10/04/07. *NJ UPDATED 8/7/09. *PE UPDATED 8/1/11. *PE
    More Information »
  • TSB #PIC3385 NHTSA ID #10020916
    • Date Announced: FEBRUARY 01 2008
    Summary: REPEATED PARK LPS FUSE OPEN. *KB (ADDITIONAL INFORMATION) UPDATED 4/1/08. *NJ
2007 Pontiac G5 Recalls CarComplaints com
Sep 21, 2015 | 2007 Pontiac G5 Gt Coupe
The power light is faint and flickering on and off
These power lights are usually of the neon lamp type, and they typically do not last a long time, especially when they are powered on 24/7. They typically fail by flickering at first, then, eventually, they just go out. If you feel confident as a "do it yourselfer", you can often replace this lamp for only a few bucks, but it does require disassembly of the control unit. Otherwise, I'd just leave it alone. If you're concerned about food loss, I'd invest in a freezer alarm. The lamp has no bearing on the operation of the compressor unit. On, flickering or out completely, the freezer will still operate normally.
May 27, 2014 | Danby 3.6 cu. ft. / 102 liter Chest...
Slight flicker with headlights. Replaced battery which was needed. Headlights still flicker. Had changed out original lamps with brighter lamps. Could this be the problem?
Bad plugs on the bulbs.Bad grounded lights wiring.Bad alternator ground.Bad alternator charge.Bad lights switch.Also ,the new lamps may show more sensibility in voltange change or put more pressure on a older bad wiring link.
Oct 26, 2013 | 2006 Ford Mustang
My projector has a blue flickering hint in the picture, is it a lamp related issue, or is it a lcd problem.....?My lamp do needs replacing because the indicator says so.......but will replacing the lamp...
blue flickering hint, means the lcd panel is break,
or polarizer is break. We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jul 12, 2013 | Epson Replacement Lamp ELPLP30 f EMP-61...
The bulb is flickering. I have replaced it but the new one also flickers
replace the ballast I can send you one cheaper than you could purchase it I have 100s of them in storage always a ballast if they flicker
Apr 10, 2013 | Verilux Modern Deluxe Natural Spectrum...
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
Mitsubishi flickering white lights on screen
this sounds like a bad optical light engine, the spots will only continue to grow in number.
See typical engine for this brand, lens on left is where image comes out and is directed on the screen.
Dec 22, 2012 | Mitsubishi WD-65733 65" HDTV
Vizio LED LCD picture flickers
Turn the backlight down all the way in the menu. Fixed mine after a year of banging on the back.
Jun 20, 2012 | Vizio E320vp 32 Lcd Black Led Hdtv, -...
Dlp has no picture only flickering lamp & timer lights.
Verify color wheel is reconnected, color wheel needs to get up to speed before lamp strikes
Jun 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
104 people viewed this question
jasbo
jasbo
