How to charge Bluetooth apt x
Do I need a adapter or batteries
    Top Expert:
  • Computers & ... Master
  • 14,162 Answers
BLUETOOTH MUSIC ADAPTER WITH APTX CODEC VIDEO GUIDE
Posted on Nov 18, 2014
How do I get pictures to my computer
1) text them one at a time to your email.
2) requires a Bluetooth enabled network adapter on a computer. Laptops are more apt to having this. Use the software on the computer and follow their steps to connect the two devices. Then access through the drive letter like a DVD or flash drive.
3) know someone with a Bluetooth enabled phone with a microsd card in? Send the pictures and microsd card in computer to get them.
Apr 24, 2014 | Motorola Mobility RAZR V3
Tip
How can I connect the USB Bluetooth bugs in Ubuntu 8.10?
<p>USB and Bluetooth connectivity errors in Ubuntu 8.10 are the result of two different errors. If you are running KDE, you have a patch on their Bluetooth connectivity problems (see Resources) to download correct. USB connection errors are the result of a bug in the current version of the Linux kernel. Run "apt-get package manager to upgrade the kernel is usually the fastest and most trouble-free. After the upgrade, the system restarts. <br /> <p><br /> <p>1. Open a copy of the console when running a graphical user interface (GUI). <br /> <p><br /> <p>2. Type "apt-get update" and press "Enter". <br /> <p><br /> <p>3. Type "apt-get upgrade" and press "Enter". The window that appears available updates. Find anything related to the kernel that "n" followed by pressing "Enter". <br /> <p><br /> <p>4. Type "apt-get install package-name" where "package name" is the updated version of the kernel. Press Enter. Confirm that you have to install the update by typing "Y" and press "Enter". Once the upgrade is complete, restart your computer. <br />
on Jun 26, 2011 | Computers & Internet
I have the LG apt x headset and when I plug it in to charge the red light turns on for a minute the it turns of and wont charge. Any idea how to fix?
I have aptx Bluetooth headset and I went ton the raipd and it is stuck on the blue light does anyone know how to reset the head phones
Sep 02, 2013 | Radio Communications
When I plug the headset into the charger it blinks red and blue and won't hold a charge. Is there anything I can do to fix this?
You might have to check the adapter for charging voltage , if faulty you will need to check the wires, the adapter, if faulty replace.
If the adapter is fine and giving the right voltage then the battery within the unit is fault. you will need to open and check to confirm and replace.
Oct 09, 2010 | Insignia Bluetooth Wireless Headphones...
Jabra 5050
Sounds like you've used this thing quite a bit, eh? Rechargeable batteries only last for so many charges. If a charge doesn't last very long anymore, you probably need to change the battery. This is not for the technically challenged. The battery may just pop out of a slide cover, or may require practically breaking the device in half to get it open, then unsoldering the old battery and resoldering a new battery in place.
But, it definitely sounds like you need to replace the battery. You may have to consider a new one - sorry.
Apr 21, 2010 | Jabra SP100 Bluetooth Wireless Adapter
My Insignia NS-BTHDP headphones don't have a red charge light anymore. The first charge out of the pack had the red light on. But now the red light doesn't come on anymore. I wonder if it is really...
The LED may have just gone bad. Keep using it untill the battery dies, then try charging it and use it again. If it works as it should it means the LED died and there is nothing to worry about, if not you may need to replace the battery.
Jun 16, 2009 | Insignia Bluetooth Wireless Headphones...
Bluetooth with my Viewty
this is an excerpt from http://www.mobileinfo.com/Bluetooth/FAQ.htm
Q: What is the range of Bluetooth transmitter/receivers? A: Bluetooth is designed for very low power use, and the transmission range will only be 10m, about 30ft. High-powered Bluetooth devices will enable ranges up to 100m (300ft). Considering the design philosophy behind Bluetooth, even the 10m range is adequate for the purposes Bluetooth is intended for. Later versions of the Bluetooth spec may allow longer ranges.
and possible headsets are from(site only for examples of bluetooth headsets,please do see other sites) http://www.mobilecityonline.com/wireless/store/productaccessory.asp?productid=22709
as mentioned the maximum range is 10 m,do see if that helps u..also bluetooth on can drain the battery faster..
hope it helps!regards!
Nov 01, 2008 | LG KU990 Viewty
Need Info
Read the manual and you will be able to connect Bluetooth TO 660 , menu Bluetooth active , be sure you LG phone is active on his bluetooth, connect and recognize will be done , you will see.
GARMIN 660 is working with a battery and also with your car adapter. I don't see any reason why it would not work on battery ?.
Your issue is not clear concerning the battery ?
best regards
Dec 31, 2007 | Garmin Nuvi 660 GPS Receiver
Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Nov 27, 2007 | LG Jabra A210 Bluetooth Adapter for...
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
