Question about Dishwashers
How do I fix the top rack & rail for my dishwasher? The roller broke away from the rack.
I've even tried super glue but that works for one wash then the rack breaks of the roller again
  • Dishwashers Master
  • 9,771 Answers
Appliance parts stores will have it or can order it for you.
Posted on Nov 19, 2014
3 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: top rack rail contently comming off the rollers.
Typically the roller wheels and the post tabs that hold them onto the sliding rack/guides will wear over time and depending on how heavily your family loads the racks, the sooner you'll need to replace them.
You can order new ones and do the job yourself which is the best solution for the situation you're describing. The only other thing to check is for the rack section that is attached to the inside dishwasher walls to make sure those screws are snug (don't overtighten and strip them out!) other than that, you still will need to replace the rollers on the extendable portion of the rack supports, etc. Hope that helps.
Posted on Jul 13, 2009
  • 57 Answers
SOURCE: I can't put back the top dishwasher rack. The
There should be plastic stops at either end of the rail that prevent the rollers of the rack from coming out of either end.
Posted on Sep 22, 2009
Top roller screw hole stripped
1)make certain all is clean and very dry
2)apply gorilla glue into stripped plastic hole and insert screw.
3)rig something up to keep it from moving for 6 hours or so
careful gorilla has a nasty habbit of pretty much destroying clothes and staining skin so be carefull. don't get carried away when applying it and maybe set down a disposable rag to catch drips.
but it is very permanent. Its what I would do
good luck
Nov 27, 2013 | Frigidaire Dishwashers
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
What glue can I use to fix the rubber seal back in my dishwasher
If all else fails use "evo-stick, serious glue"
Feb 27, 2012 | Dishwashers
Top rack rails came off the rollers
How to replace the adjuster on the top rack of KitchenAide dishwasher model number KUDS35FXSS1
Feb 03, 2012 | KitchenAid 24 in. KUDS01FLSS Built-In...
The top rack is very stiff pulling in and out, at a certain point.
Check that the rollers on the rack are correctly seated in the sliding rail, and that all the rollers are ok and intact and turning.Also check that you haven't bent or dislodged the sliding rail and that it is fixed to the dishwasher properly, ie nothing has come loose.
hope that helps
Jan 25, 2011 | Hotpoint Dishwashers
I have a MieleG2142. One of the racks is not sliding smoothly which I believe I have narrowed down to one of the wheels in the rail guides not turning. How are the rail guides removed?
Hi dear.Try this.Pull the top basket towards you.Check on the side (if you can) back of the basket two of the wheels on top row should be on rail guide & third one just under the rail guide to support the basket.It should be even on both side of basket to run smoothly.If not pull the basket all the way towards you & lift up the basket you are holding.Basket will be free to come out of rail guide.(Please check,are the rail guides running in & out freely without basket?If not there are two plastic wheel inside of the each rail guide one or two of it must be damaged.That needs to be replaced.Please also check side wheels on the basket,they sould be freely turning.If not needs to be replaced.) If that did not work out,try to put back the basket even way to rail guide the way took it off.Contact Miele for assitants.Thanks.Goodluck.
Aug 07, 2010 | Miele G2142 24 in Builtin Dishwasher
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
I can't put back the top dishwasher rack. The railing does not seem to hold it, even though there is no damage in the railing. The top rack could not be held by the rollers
Sep 22, 2009 | Maytag Dishwashers
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Top rack rail contently comming off the rollers. The rollers are wobbly, tried to tighten but will not go any tighter. are there better rollers available? PLD2850RDC2
Jul 13, 2009 | GE 24 in. GSD4030Z Built-in Dishwasher
Dishwashers Logo
109 people viewed this question
Top Dishwashers Experts
