Question about Optoma TX1080 Projector
The screen turn green on my Optoma TX1080 DLP projector what is the problem
The picture plays great for about 5 minutes and then the screen turn green
    Sergeant:
  • 192 Answers
Usually, that means that there is an issue with the cable connecting the computer to the projector. Check to make sure none of the pins are bent or broken. Aslo see if a differnt cable works correctly.
Posted on Nov 18, 2014
webkruzer1
  • 17 Answers
SOURCE: My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
Posted on Apr 09, 2009
SOURCE: ThemeScene HD65 projector, red thermometer light is on
I simply shut the projector down (had to pull the power cable) and when starting up again it was working fine and has since then.
Posted on Oct 05, 2009
SOURCE: blotchy colors on optoma hd80
i had, have the same problem i also replaced the bulb then shortly after the power went out no standby light or anything. From what i've read so far it seems like a power supply issue so i ordered two power supplys from optoma 1 for lamp 1 for the unit waiting on delivery from CA they were $ 99 each if this work i'll be one happy camper. Three years no problems it's a great machine with incredible picture using 106" screen
Posted on Jan 29, 2010
SOURCE: How to connect the Optoma Pico PK-101 DLP to a laptop
You have to buy a 17€ converter.... here on my website, is a diagramm on the B chapter that explain a lot.
http://shadar.spacequadrat.de/?p=121#more-121
Here is the link to buy one converter
http://shop.ebay.fr/i.html?_nkw=pc+VGA+to+converter&_sacat=0&defsort=15&LH_BIN=1&_sop=15&_odkw=pc+to+converter&_osacat=0&bkBtn=&LH_ClassifyToggle=0&_trksid=p3286.m270.l1313
Posted on May 13, 2010
SOURCE: Help! Our Optoma DLP
There is a lense behind the main focus lense that's causing this. Flakes of the colored tint are coming off causing white light to shine through. If you look at your projection, you can see black spots as well, these being the flakes that have re-located themselves. I dug into mine deep enough to diagnose this, to actually replace the little lense would be a little tricky. The unit has to be mostly disassembled. Also I haven't been able to locate a vendor who sells the part. Optoma wants you to send it in so they can do the repair, and won't part w/ these component level parts.
Posted on Nov 20, 2011
Optoma HD20 brightness changes periodically
I read the above and it ended up just being my HDMI cable contact being a little lose from me moving the unit around all the time. Just pushed it in and we're back in action!
Jun 11, 2012 | Optoma HD20 DLP Projector
Optoma 72 projector goes black after 2 minutes Projector stays on but no picture
Does the lamp go off, or does the "shutter" block the light out.
Mar 22, 2011 | Optoma HD70 DLP Projector
Optoma H70 picture flashes on and off
This is how my problem with the power not going on started. I cleaned mine and it was running much better. I decided to give it a good cleaning, but now the power won't turn on. Try at your own risk as this could happen to you as well. Just a note, I have had mine for 4 yrs with the same bulb, just over 6000 hrs. I was lucky until now.
Mar 30, 2010 | Optoma HD70 DLP Projector
Does it run longer?
Mar 01, 2009 | Optoma HD65 DLP Projector
Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Jan 31, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Turns more green
apart from the lamp (which ive had several times) we did have a DLP chip cause this.
Nov 15, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma TX1080 Projector Logo
108 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
