Question about Bretford Office Equipment & Supplies
How do I fix my bretford manual projection screen. It will not roll up?
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
My quartet projection screen will not go back up. I think someone pulled it down too far.
The problem is most likely a damaged spring end cap. As you face the screen from the front, this is the cap that covers the right end of the cylinder that encloses the screen material. The cap is held in place by 3 Phillips head screws. If you remove the spring end cap, you will see a slot in it that is designed to hold the spring assembly stationary as you pull down on the screen. If this slot is damaged, then the internal spring inside the roller will lose tension. The fix is to pull out the screen & roller assembly, roll it back up manually, then replace the spring end cap with a new one. (I believe the part # from Quartet Apollo is K0329). The cap at the other end has a cup receiver designed to accept the pin end that is on the left side of the cylinder that houses the screen material. The tricky part is fitting the pin end back into the pin end end cap. It is easier with 2 people. If you fashion a short hook out of a coat hanger. you can use it to lift the pin end into the pin end cap. There are part #'s and exploded diagrams on the Pegasus part sales website: http://shopping.netsuite.com/s.nl?c=440001. The site is down now for maintenence, but it should be back up soon. HTH
Mar 13, 2009 | Quartet gbc 550S 71" 1:1 Projector Screen
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi mod. vs-5072 rolls how fix?
check for swollen capacitors- bad capacitors will cause the screen to roll. If the top of a capacitor even looks SLIGHTLY puffed up, replace it!
Dec 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Rear project TV problem
yes it can be fixed depending on your model number if its the VS50605 they have a kit to repair the PIP module which controls vertical sync (Rolling) or you can bypass the module to correct it but you would lose the PIP function. Let me know if you need more info.
Apr 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Rolling screen
Does the onscreen menu roll too? If so, vertical hold needs to be adjusted. Not sure if on this model if that's in the service menu or a manual adjustment on the motherboard. Keep searching google and see if anyone else has had that issue too.
Good Luck!
Mar 14, 2008 | Mitsubishi WS-65807 65" Rear Projection...
232 people viewed this question
Top Bretford Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Bretford Office Equipment and Supply Expert? Answer questions, earn points and help others
