Question about Brother PC-8500 Pacesetter Embroidery & Sewing Machine
<!-- from fixya rte -->Pc-8500 how to calibrate touch screen - Brother PC-8500 Pacesetter Embroidery & Sewing Machine
    New Friend:
  • 185 Answers
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Posted on Nov 18, 2014
My Janome mc8000 touch screen is responding all wrong,touch one pattern and it does another but the re calibration won't work
sounds like there could be something wrong with the computer probably needs to be serviced
Apr 01, 2016 | Janome Sewing Machines
How do i do a screen calibration on a PC-8500 sewing/embroidery machine?
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
match.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Position of Touch Panel.
It's been awhile, but I think you go into the test mode then hit one of the hard keys (start, threader, reverse). I know there is a backdoor for this.
On newer Brothers you touch the screen and hold while powering on, but I'm not sure yours does it that way.
Oct 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Husqvarna quilt designer II will not calibrate
Sounds like the touch screen has gone bad. You should take it to your nearest authorized husqvarnaviking dealer. You can find your nearest dealer at http://www.husqvarnaviking.com/us
May 11, 2014 | Husqvarna Sewing Machines
The touch screen of my Bernina 580 stopped working today and it was perfectly OK yesterday. Is there a way to fix it on my own or should I look for help?
Calibrate the diplay
The Display calibration can be opened as follows:
- turn off the sewing-/embroidery computer
- touch the two needle positioning buttons on the front panel and keep them pressed
- turn on the sewing-/embroidery computer and release the buttons as soon as the Display appears
- touch the calibration icon
- touch the center of the cross using the touch pen
-- the cross moves to the next position
- repeat this until all three positions shown are calibrated
-- the Display is closed
-- the adjustment is saved
Apr 13, 2014 | Bernina Artista 180
Screen calibration screwed up.. need to know how to reset it?
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Dec 30, 2012 | Bernina Artista 180
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
Touch screen cannot be calibrated
We already fixed the problem, but just the same, our own premium plan is going to cost you ( an eye for an eye)
Thanks
Jun 21, 2009 | Husqvarna Designer I
I have a pc-8500 and the top thread breaks constantly. I have taken the side off...and see no thread tangled inside...as well as haven taken off the bobbin plate to make sure there is no thread tangled...
OK. I was just being kind of an idiot. I replaced the bobbin spool with one that came with it and it's working fine now. Apparently this machine is very picky about the type of bobbin you use.
Nov 05, 2008 | Brother PC-6000 Pacesetter
Brother PC-8500 Pacesetter Embroidery & Sewing Machine Logo
99 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
