Have a Bosh classic XX6 Vario Perfect, after the wash cycle has finished, I have to wait 10 to 15 minutes before I can switch on another wash, because when button pressed for next wash, it does not wo
Have a Bosh classic XX6 Vario Perfect, after the wash cycle has finished, I have to wait 10 to 15 minutes before I can switch on another wash, because when button pressed for next wash, it does not work straight away. any help would be welcomed.
2 Suggested Answers
  • 6277 Answers
SOURCE: Took delivery of Bosch Classic
Apart from trying the following, although I would NOT expect the filter or pump to be blocked in a NEW washer, get back in touch with Comet!!!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 29, 2011
I have Bosch vario perfect washing machine and when I switch it on today cl appears on the screen what does this mean
too much soap causing a varience in motor induction and that is detetected by the controls then its retrys by flushing the soap taking way longer than usual and never completing cycle finally flashes a CL which mean cleaning lady done flubbed. just a guess
Dec 29, 2016 | Bosch Washing Machines
Bosh classic washing machine fault no F 21
Kindly read the manual or see a specialist.
Jul 21, 2016 | Washing Machines
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
I have a Bosch Logixx 8 Vario perfect washing machine. Its only a few months old. My problem is that the conditioner is still in the drawer after the wash is finished. What do I do
Bosch Logixx 8 Vario problem is that the conditioner is still in the drawer after the wash is finished This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 17, 2011 | Audiovox Bosch 718 World Cellular Phone
WWD45 machine will not comlpete wash cycle, have been advised to clean filters which are all clear but problem still persists
The problem with BOSH model WWD45 washing machine not comlpleting the wash cycle going On & On endlessly, in my case was temperature related. This fault was diagnosed by setting temperature to COLD, instead of 30? or 40?. The machine was able to complete its full cycle with no problem. In my case I found the heater element to be faulty. When the wash is set to a certain temperature, the program awaits for the temperature to be reached. Because the resistance in element is broken the water never heats up, therefore the program cycle never finishes its waiting for a temperature feedback. Alfredo da Silva
Nov 13, 2009 | Bosch Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
AEL Lavamat 509N
These machines do not release the door immediately after wash cycle is complete. After final spin cycle wait until you hear a click sound.The door will then be able to be opened. This takes uproximately three minutes.
regards,
Alf
Dec 04, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
