I have a 39pfl2608/f7 philips tv. it has pink tinge around anything whit on the screen. its not all pink just on the edges of white imgages
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Check the Va & Vs voltages to the panel, too. These voltages are to be noted well, even after replacing a new power supply board. Details about this can be note at the silk screen on the panle [inside].
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Nov 18, 2014
Can I fix my LCD Television with broken display screen with a slightly different model?
I have not been able to ascertain the individual panel part # for these units, so my suggestion is as follows:
remove the back from both units & verify the part# of the panel for each. If they have identical part# you can swap, if they are different, try to google each # to see if they may be interchangeable.
Mar 04, 2015 | Televison & Video
Philips 39pfl2608
what is the cost of Philips 39" 39PFL2608/F7 screen
Jan 05, 2014 | Philips 2000 Series - 39" Class 38-5/8"...
Philips 47pfl7403d/f7 LCD TV When the TV is
first you may check the T-CON board if thats ok then the problem is coming from your set panel .
Sep 01, 2013 | Philips Televison & Video
My tv has a red tinge to it. convergence?
TWO THINGS:
1. GO into customer menu and select convergence--you should bring up a grid of lines--see if red is skewed or the yellow lines are outlined with red edges.
2. Look at the attached photos and tell me if they look ANYTHING like your problem.
If this information or the photos helped you, rate this solution as very helpful as I do this here for free.
SD TECH
remember, no two sets will look exactly the same but you will know if this is your problem. If it is I can tell you how to fix it for under 30 dollars total parts cost.
Aug 18, 2010 | Philips 55PW9363 55" Rear Projection...
Background, e.g. or sky, or anything white are pink. what is the
Is this in all the SCN?
I'm sorry, but in this case there isn't much more to do than to Trade up. Since this model is no longer repaired due to spare parts shortage.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 03, 2009 | Kodak EasyShare CX7330 Digital Camera
32" philips flat crt PINK SCREEN
The set has detected a problem internally and does not "start" to precvent further damage. i would take it where you got it sweety
Sep 05, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
My Philips 51PW9363 has pink and green colors only!!!!
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 05, 2009 | Philips 51PP9200D Television
Yellow tinged edges
Your problem is most likely your Blue and Green lens' inside the light engine. It's not something you can replace yourself. I worked for Philips for 14 yrs. repairing the LCD projectors the last 6 Yrs. Call philips and get the number of an ASC in your area that has repaired projectors.
Feb 14, 2008 | Philips Garbo Multimedia Projector
Photo-copied Blk & White pictures come out with a pink tinge instead of blk & white.
haven't come across this problem myself, but renew all the ink cartridges, using Epson genuine only and no refills
Feb 09, 2008 | Epson Stylus RX500 All-In-One InkJet...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
