Question about Jeep 2012 Grand Cherokee Laredo 4WD
How do I repair a 2012 Jeep Grand Cherokee with no heat coming from Drivers side?
There is no heat on the drivers side but there is heat on the passenger side. How to repair?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Pull dash apart and check all vaccum lines for leaks and ducting doors to make sure they can move freely
Posted on Nov 18, 2014
2 Suggested Answers
  • 62 Answers
SOURCE: 2000 Jeep Grand Cherokee Laredo Power Locks going out
thats kinda 2 things.. lol... but the back pass door.. your actuator in the latch could be bad or someone that used a slimjim to unlock the car on that door bent the rod.. does it move at all when you hit the power lock button ? if it moves some that it could very well be a bent rod.. or the actuator is stuck and needs to be replaced..
Posted on Dec 10, 2012
Spark plug location on a 2012 jeep grand cherokee
Look in the Chilton manuals or ask your local parts dealer. Be sure the engine is cold when changing them.
Amazon com chiltons jeep repair manual
Spark plug location on 2012 jeep grand cherokee
Mar 03, 2015 | 2012 Jeep Grand Cherokee
2002 jeep grand cherokee drivers heated seat quit working! elments or control module? swtich lights
Hi before making a suggestion, It would be nice to know if only the drivers sest is affected, or is the passanger side also affecte. This will permit in analysing if it is the element or the module. Thanks for the additional information
Feb 25, 2015 | 2002 Jeep Grand Cherokee
JEEP CHEROKEE LE DRIVER SIDE HEAT DOESN'T WORK
If you have heat on the passenger side then this is just a simple case of the hose supplying the heat has com off of the heat exchanger
Aug 26, 2012 | 2001 Jeep Grand Cherokee
Heat works on drivers side passage side blows cold
Hi I have same problem with my cherokee year 2000 not been able to have proper look at it yet done quick fix .Removed passenger out let pipes and blocked up outlet .Then disconnected drivers side rear pipe and ran suitable tube behind center consol to passenger footwell .gives heat to both sides of car .When weather improves will try to do proper repair i supect it to be temp solenoid on heater unit have found location for drivers side one but cant find passenger one .
Jan 12, 2010 | 2001 Jeep Grand Cherokee
2000 jeep grand cherokee heated seat drivers side low setting light is coming on but high setting no light
hi this could be down to bad conetion on the wireing , check all conections , clean them down , if that doesnt work then its in the electris somewere . you need to trace it ,
Jun 22, 2009 | 2001 Jeep Grand Cherokee
97 Jeep Grand Cherokee only blows heat and ac out of dashboard
There is a vacuum leak under the hood. If it's a 6 cylinder, look on the drivers side for a vacuum line that runs vertical with a 90 degree angle fitting to the manifold. That one usually comes off. If it is a V8 look on the battery side for a broken or corroded vacuum line.
May 18, 2009 | 1997 Jeep Grand Cherokee
2001 Jeep Grand Cherokee which fuse controls heated seats?
Fuse # 20, located in the Junction Block (interior, drivers side). This is a ten amp fuse.
CLICK_HERE
Read the information at the above site. The TSB (technical service bulletin) may be of interest to you.
Nov 15, 2008 | 2001 Jeep Grand Cherokee
Temperature control only puts out heat on drivers side
The digital thermal control is bad. The part usually goes out after 6 years near 80,000 miles or sooner with excessive use. The controler box behind the dials used for temp. has a spring inside which always breaks, the part is non serviceable, in other words, you can not buy the spring, you must replace the entire unit. Unfortunatly this is a dealer only part.
Nov 11, 2008 | 2002 Jeep Grand Cherokee
Heated seats are not working but light is on
Sounds like the same problem I had. I brought it to the Jeep dealer and they told me that the heating element in the seat stopped working. They told me that the only way to repair was to take the seat apart and replace the heating element in the seat. Of course they will charge you the standard $80 to tell you this. and then quote you $500 plus to repair. I can't even remember how much, I have decided it was not worth it.
Also this website could help you:
http://www.wjjeeps.com/seats/seats.htm
Oct 31, 2008 | 2001 Jeep Grand Cherokee
Jeep grand cherokee heater
Pass. side blend air door motor is probably bad.
Oct 25, 2008 | 2000 Jeep Grand Cherokee
Jeep 2012 Grand Cherokee Laredo 4WD Logo
60 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
